1.6RR and stock springs?
Old Feb 18, 2003 | 12:48 AM
stevil's Avatar
Question 1.6RR and stock springs?
I'm putting on a set of 1.6 Pro Magnums, but nothing else (besides studs & guideplates), no cam. Only .030" more lift and fresh springs, only 26K miles.
I see aftermarket springs advertised: valve lift up to .600"
So what are the stock springs rated at? Can I just stick with the stock springs? Or will there be problems? What springs would do the job, and not need any machine work for the heads?
Old Feb 18, 2003 | 12:50 AM
Dr.Mudge's Avatar
Its been done, but it shouldn't be done. I seem to remember .490" for stock springs? Either way, on at least I believe the exaust side, every year cam will go beyond its rated lift at 1.6, grab some LT4 setup springs/retainers etc or something else.
Old Feb 18, 2003 | 01:16 AM
stevil's Avatar
Hmm
Yeah, looking at stock gross lift numbers of .448 & .458, the 1.6 rocker arms would put it at .478 & .488. I was hoping the springs were rated an even .500, but .490 seems too close.
LT4 stuff would probably be perfect, but prices are about the same as aftermarket... and I plan on heads/cam sometime later. So now I have to decide between getting good stuff now or later. Damn, I just wanted to keep this cheap and simple.
Thanks for the help.
Old Feb 18, 2003 | 03:46 AM
joeSS97's Avatar
It can be done,I have been doing it for about 20k miles,I do have a set of CC 987 springs to go on.I plan on putting a cam in in a few months.If you do it check each one for coil bind.They will be close to it.
Old Feb 18, 2003 | 04:40 AM
doodad's Avatar
Did you check with Jason at Sam Taylor Buick? He just quoted me $465 for the whole LT4 hotcam kit.
Old Feb 18, 2003 | 08:11 AM
96Z28man's Avatar
I wouldn't do it, you can get some LT4 springs real cheap.
Old Feb 18, 2003 | 09:44 AM
turbo_Z's Avatar
if you are ever planning on a cam then i suggest putting on a good spring now. i went ahead and installed a CC987 spring kit and 1.6 pro mags in anticipation of a cam in a few months. for the work and time envolved with changing springs...trust me you want to do this only once!
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
