what is a throtle enhancer by casper electronics
Old Feb 17, 2003 | 11:41 PM
red96z's Avatar
is it like the power tune in your hpp or can u use this in combination with your hpp
Old Feb 17, 2003 | 11:48 PM
ScottZ's Avatar
It is an electronic gizmo that intercepts the signal from the Throttle Position Sensor (TPS) and modifies it to show the computer WOT at 70% throttle. This initiates WOT open loop, which is a more aggresive timing/fuel map that ignores input from the O2 sensors. It does not change any programing, it just initiates WOT sooner. It is compatible with stock or modified (HPP, etc) tuning.
This supposedly gives you better throttle reponse and mid range power.
IMHO, it is money that could be spent better elsewhere, but I haven't heard of any complaints.
Scott
Old Feb 18, 2003 | 11:20 AM
red96z's Avatar
has anyone else had any experience with this
Old Feb 18, 2003 | 11:26 AM
JAFO1994's Avatar
What does it look like and where does it go? I'm just wondering if my car has it on, since I don't have history on it and with my programming it seems to have the problem of being in WOT mode at half throttle. Mostly the problem is down shifting at 6000 rpm's.
Old Feb 18, 2003 | 12:16 PM
ba96ta's Avatar
I talked to a guy with one a while back and he said it made his car run smoother amd got ride of the surging in acceleration no added performance
Old Feb 18, 2003 | 12:59 PM
drop top steve's Avatar
It gives you pe mode at 70% tps instead of 80% (stock). It's mounting ears are slotted for easy adjustment, a good deal,IF you need a new tps.
Old Feb 18, 2003 | 02:31 PM
teke184's Avatar
looks something like this
Old Feb 18, 2003 | 03:35 PM
The one I saw replaced the TPS, this one goes inline.
Old Feb 18, 2003 | 03:50 PM
chesee48's Avatar
Doesnt ebay have a guy that sells a knock-off version of this? I think it was like 64.99 or something like that and you can have your choice of color
Old Feb 18, 2003 | 03:57 PM
chesee48's Avatar
Here it is at ebay
drt
Sep 27, 2015 04:39 PM
karpetcm
Aug 14, 2015 03:02 PM
Henson071
Aug 4, 2015 09:32 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
