stock oil pan baffle
Old Feb 17, 2003 | 12:51 PM
ryaskovic's Avatar
I've got a 383 LT1 shortblock with a clearanced stock oil pan. It does not have the baffle in it like the stock pan did. I'm assuming the stock baffle won't fit with the 383 rotating assembly and I should just run without it? I'd check the fit myself but I've already got the engine in the car (for the most part).
Thanks,
Rob
Old Feb 17, 2003 | 12:55 PM
NOMAD's Avatar
Cool
I dont' have a windage tray on my 350 and I haven't had a single oiling problem after about 2,000 miles. Oil pressure never fluctuates or anything...
-Shannon
Old Feb 17, 2003 | 12:59 PM
ryaskovic's Avatar
Guess I should also mention this is my daily driver for the most part. I drive hard on the road and run 1/4 mile every once in a while. No roadracing or autocross though.
Rob
95Z28
96z's Avatar
96z
I dont think there would be a problem but you are probably losing some HP do to all that oil flying around.
Old Feb 17, 2003 | 01:05 PM
TedH's Avatar
Windage+ stroker=problems.
I have a Canton pan. It fits like crap but I don't have a windage problem. If you are doing a stroker don't skimp on the little things to protect your investment. A good oil pan is kind of like having an updated virus protection program on your computer.
Old Feb 17, 2003 | 01:17 PM
drop top steve's Avatar
Re: stock oil pan baffle
Thanks,
Rob
You removed the oil pan baffle, or the windage tray? Two different items.
Old Feb 17, 2003 | 02:19 PM
ryaskovic's Avatar
Re: Re: stock oil pan baffle
I didn't remove anything. I ordered a shortblock from Nu-tek and the oil pan that came with it looked just like mine, except it had been clearanced for the 3.75" stroke on the bottom and sides.
With the oil pan off, on a stock engine, you can see a flat plate that is bolted to the oil pump/pickup assemby. This plate fits between the oil pickup and the crank. The GM manual calls this a "baffle". The assembly I got from Nu-tek did not have this and I assumed it was because it wouldn't work with the increased stroke. My question is, is this the way it should be or was I supposed to remove the baffle from my stock setup and install it on the new setup?
Thanks,
Rob
95Z28
Old Feb 17, 2003 | 02:43 PM
ryaskovic's Avatar
FYI,
This "baffle" also bolts to the center main caps.
I heard back from Nick.....this won't work with the additional stroke so don't use it.
Thanks,
Rob
95Z28
Old Feb 17, 2003 | 11:27 PM
96z's Avatar
96z
Hmm this is interesting. With my stroker we are going to be using a milodon windage tray seen here . We test fitted the one we had laying around on the block and everything fit good. This would replace the stock flat piece you are talking about. The other flat piece thats welded to the inside of the pan may need to be removed or just clearanced.
Old Feb 18, 2003 | 08:39 PM
97 RedSS's Avatar
Yes I would get the Canton..I didnt and am going to have to drop the kmember and install the canton here next week...Cant wait though so I can actually drive the car and not have windage issues..Havent been able to take it above 4k with the stock oil pan yet
Cody
Old Feb 18, 2003 | 11:55 PM
96z's Avatar
96z
Just thought I bring this back up to the top. Has anyone used an aftermarket windage tray?
Is the canton one built into the pan?
Old Feb 19, 2003 | 12:56 AM
I would recommend a screen style windage tray with a scrapper plate. Summit or jegs can supply it.
HectorM52
Jul 30, 2017 11:46 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
