LSD / 3.73's
Old Feb 15, 2003 | 10:03 PM
KevinAce's Avatar
LSD / 3.73's
Hey,
I see a lot of places have LSD for about $100:
Differential, O.E.M. Zexel-Torsen Camaro/Firebird - $94.50
Is this all that's required? Can any shop basically put this on with no other parts? Also, how hard would it be? What would labor charges typically be? Same questions go for gears (3.73). Is it best to get them both installed at the same time?
Let Me Know,
Thanks,
Kevin
Old Feb 16, 2003 | 11:16 AM
94GrayV6's Avatar
Any shop should be able to do it no prob. Save some labor $$ and have them both done at once though.
Old Feb 16, 2003 | 03:16 PM
djcam's Avatar
any shop should be able to do it. definately have them do it at the same time as the gears. go to slponline and get the take-out diff from a LS1 car. definately worth the investment. that should be all u need. mabey a new crush sleeve.
Old Feb 16, 2003 | 05:27 PM
KevinAce's Avatar
Okay, thanks for the info. Any recommendations on where to get some 3.73 gears on (easiest to use with a stock 99 Camaro) with everything that I'll need (not for me to install, but a shop)?
Old Feb 16, 2003 | 10:33 PM
djcam's Avatar
go to www.thunderracing.com and order some Motive gears
they are the quietest gears out there IMO.
Old Feb 17, 2003 | 02:12 PM
Bliggida's Avatar
If any gear set isn't quiet, I would first blame installation. Gears with proper lash shouldn't make any noise. Even 4.88 and 5.13 gearing.
Old Feb 18, 2003 | 11:13 PM
Blue89Bird's Avatar
Yeah get the GM/Motives dont save money and buy em used either.
Old Feb 18, 2003 | 11:19 PM
WickEdSix98's Avatar
all gears wont be quiet...Richmands make a little noise,but its not enough to matter..
Old Feb 19, 2003 | 03:36 AM
KevinAce's Avatar
Given I'm going to a place with the propar tools, what will I need on top of the $500 Motive 3.73 gears (ring / pinion only, right?)?
Old Feb 21, 2003 | 07:32 PM
Joshs99BlackBeauty's Avatar
I would go with 3.42 gears instead of 3.73. Those 3.73 kill top end
Old Feb 21, 2003 | 08:27 PM
Bliggida's Avatar
will not.
Old Feb 21, 2003 | 09:42 PM
Originally posted by Bliggida
will not.
you sure about that? everyone i have talked to said 3.42 are better than 3.73
Old Feb 23, 2003 | 03:28 PM
Bliggida's Avatar
More gear means more torque to the wheels. Whatever power you have at the engine gets mulitplied by your transmission gear ratio and your final drive ratio.
So 200 HP x 0.74 (M5 5th) x 3.23 = 478 multiplied horsepower
but 200 HP x 0.74 x 3.73 = 552.
The bigger number will accelerate faster.
Now true, the faster you accelerate (being dependant on gearing) the slower your top end speed will be. But it's not like it kills it.
In stock form the 3.23 gearing has a theoretical top speed of 172 MPH (if it had the power to pull that - which it don't)
With 3.73's your top speed is decreased only by 23 MPH - leaving you with a 149 MPH top end speed. When was the last time you went 149 MPH in your V6??????
If you have more power (by increased gearing) going to the overdrive gear, it is going to pull harder. Top speed is only slightly decreased. But the decrease is so insignificant, because I have yet to see an A-typical modified V6 F-body breech 140 MPH!!! Just not enough power so gearing really isn't even a factor.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
