HELP, Header question - steering linkages removal!
Old Feb 15, 2003 | 04:58 PM
pillagenburn's Avatar
Hey,
I'm putting headers in my 96 camaro z28. I need to know how to remove the driver's side steering linkage (i think its where the rage joint is?) If anyone can tell me how to do this, or any place I can find Illustrations, that'd be great - I need to get this thing off! Also, are there precautions i should take when removing it?
thanks!
-Lane
Old Feb 15, 2003 | 06:03 PM
CSJTA's Avatar
I would just take it loose at the other end, not the rag joint end, but the end near the firewall. If you look at the linkage, there is one thru bolt on the end near the firewall, just remove that bolt and the linkage slides apart. If I'm not mistaken, there is a plastic cover that covers this part up, just remove the cover and you should see the bolt.
Old Feb 16, 2003 | 10:40 AM
Bud M's Avatar
I separated it at the joint in the middle. Getting it back together was kind of difficult. I had to use a grinder to enlarge the opening enough to get it started going back together.
Old Feb 16, 2003 | 10:44 AM
DubbyZ28Camaro's Avatar
hmmm...i definitely never had to do that...I just got under the car and pryed on the manifold and *POP*...there she fell...I did think about taking that apart once then I realized how much of a bitch that was going to be to get back together...oh, and the prybar MANGLED my oil filter since I was using that to pry against.
Old Feb 16, 2003 | 12:20 PM
Mikey97Z's Avatar
Cool
Remove the upper bolt near the firewall, and the bottom bolt near the steering rack. then slide the linkage up further onto the steering column shaft (coming out of the firewall). That will make enough slack to pull the bottom off of the steering rack gear. Once the bottom's free, slide the top end off the steering column shaft. To install it, do the reverse ... Slide it "too far" up the steering column and you'll be able to mount the bottom. Then get it situated and replace the bolts. I put some antisieze on mine because they're gettin rusted and hard to turn.
Old Feb 16, 2003 | 12:43 PM
Birdie2000's Avatar
I recently had to change my rag joint and had to remove that linkage... it was a pain. I had to beat it off of the steering column with a rubber hammer. When I finally got it off, I put some engine oil inside the linkage where it slips over the shafts at either end and could take it on or off just by pushing/pulling with my hand.
Just a suggestion.
cmdeshon
Dec 27, 2014 10:06 AM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
