valve covers to fit 1.6 rr's?
Old Feb 15, 2003 | 01:39 PM
94droptopz's Avatar
i've seen some before but i cant find them now. does anybody know where i can get a set of aftermarket covers to fit 1.6 rr's? thanks
Old Feb 15, 2003 | 01:40 PM
RamAir95TA's Avatar
You can use stock valve covers, but the supports on the inside just need to be trimmed on the inside. No problems.
Old Feb 15, 2003 | 02:27 PM
mojo's Avatar
If you use the Crane gold 1.6 rockers,you don't have to do a thing to the stock valve covers.
Old Feb 16, 2003 | 08:22 AM
badass383's Avatar
Look at GM performance parts number 12497978 or 979. I got them and I think they're the best looking I've seen yet. They are actually made by Proform under number 141-130 but I don't know if you can get them through any other sources. They fit my 1.6 magnums fine and I have 7/16 studs. If you need it https://www.spoperformanceparts.com/ is GM performance parts. Go to SB its in there.
Old Feb 16, 2003 | 10:27 AM
SMOKD U's Avatar
LT4 Valve Covers are the best way to go!!!
Old Feb 16, 2003 | 10:59 AM
94droptopz's Avatar
thanks a lot badass thats the ones i was looking for. im also running 1.6 pro magnums so i think these will work great. thanks again
Old Feb 18, 2003 | 05:03 PM
M93Z's Avatar
Do the GM Performance valvecovers clear the alternator?
Old Feb 18, 2003 | 05:06 PM
RamAir95TA's Avatar
If they are LT1-specific, they should.
Old Feb 18, 2003 | 05:39 PM
M93Z's Avatar
I don't believe they are LT 1- specific, that's why I asked about the alternator.
Old Feb 18, 2003 | 05:57 PM
Mindgame's Avatar
Don't know if you're looking for the "factory look" or not but the pro-line aluminum jobs will clear, plus they have the alternator clearance built in.
http://www.flatlanderracing.com/index.html
-Mindgame
Old Feb 19, 2003 | 04:59 PM
M93Z's Avatar
-Mindgame
Thanks Mindgame,
Anyone know if the Pro-Line covers clear Comp 1.6 NSA roller rocker without grinding?
Old Feb 19, 2003 | 06:34 PM
badass383's Avatar
Sorry I can't answer the question about the alternator. I have a blower and all different brackets and did not have a problem fitting them up. Also I got mine from Bobby Murray chevrolet and noone else could touch that price. I still say they are the best looking ones around. Good luck.
Old Feb 19, 2003 | 06:40 PM
Derrick Redd's Avatar
I'm using the Crane Gold 1.6's with the stock valve covers also.
Old Feb 19, 2003 | 07:44 PM
klbjoc's Avatar
I have the # 12497979 covers and I had to grind on the back of the alternator to get them to fit. It didn`t take much though.
They also look great!
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
