those resistors people are selling on ebay as performance chips
Old Feb 15, 2003 | 12:32 PM
KeVMaN's Avatar
They claim to gain 20hp (lol) by leaning out the motor. Well, i'm running really really rich (can smell it, getting ****ty milage) and want to know if a setup like this would help me out any or if it was dangerous to control the a/f like this? thanks
Old Feb 15, 2003 | 12:42 PM
Javier97Z28's Avatar
Moderator
No, don't do it the ghetto way. Do it properly and have someone burn you a chip for your ECM.
Old Feb 15, 2003 | 01:06 PM
Dr.Mudge's Avatar
You can try a fuel pressure regulator, but you have no idea what AF your moving yourself to by playing with the injectors that way.
You sure you dont just have a simple exaust leak?
Old Feb 15, 2003 | 01:15 PM
KeVMaN's Avatar
well I installed the exhaust about a month ago, I guess I can check all the bolts again? I don't see how that would make it run rich tho
Old Feb 15, 2003 | 01:18 PM
KeVMaN's Avatar
well having only 2 mods I think it would be a waste to get a chip already, because as soon as I do something else I'll need a new one. I don't have the cash to do it once, much less every time I manage to save enough for a mod
Old Feb 15, 2003 | 02:12 PM
Gripenfelter's Avatar
I was running rich.
I used an adjustable fuel pressure regulator, bigger TB, and ACCEL ignition to lean myself out.
Also a 93.
Old Feb 15, 2003 | 02:16 PM
Style's Avatar
if you have an exhaust leak before the pre-cat o2 sensors, the sensor would read lean and try to richen the mixture.
Old Feb 15, 2003 | 02:20 PM
KeVMaN's Avatar
so it would be the manifolds/y pipe?
Old Feb 15, 2003 | 02:31 PM
Dr.Mudge's Avatar
If your O2s see more O2 than they are supposed to, they will add more fuel because the computer thinks your "lean." If you messed around with the Y pipe at all this is a possibility.
If your 93 is the same as my 94, which I believe is correct, you have one O2 in the Y pipe (left, drv side) and one in the exaust manifold on the pass side (right).
Old Feb 15, 2003 | 02:47 PM
BigBadBlack93Z's Avatar
ok, the chips on ebay are a 4.7k resistor right? it goes in the IAT to make it think its 50 outside. On a 93 you can play w/ the fuel regulator to lean it out. Just remember to by a 93 specific reg.(its like the one on a vette). On newer models they will slowly compensate for the higher or lower psi you give it, the 93 will not.
Other hints are, change your plugs/wires, change/clean your air filter.
Old Feb 15, 2003 | 03:55 PM
Teal94Z's Avatar
dont waste your money on that scam, its not a chip, its a 5 cent resistor....do like others said, a basic tuneup will do wonders...
Old Feb 15, 2003 | 04:22 PM
Fear The Z's Avatar
Originally posted by Gripenfelter
I was running rich.
Also a 93.
What did you set the pressure to? And when you do set it, doesnt the PCM set it to where it thinks it needs to be?
Old Feb 15, 2003 | 04:38 PM
ChewyChevy's Avatar
Hey Kev,
I'm having the same problem in my 93Z of it running rich. I'm probably going to do what most people are suggesting here. When I get my Jet-Hot's and put them in I'll be swapping out the O2's, plugs, wires, AFPR and getting my car scanned from someone to check if everythings in running order. I understand that getting it tuned is an expensive option (150 from PCMforless and 300ish from a dyno tuner). However with all that I'm doing, if it doesn't fix my running rich problem, I will end up paying the big bucks to get it tuned right.
Alex
Jlo
Feb 3, 2015 09:41 PM
Moshbmx1
Jan 20, 2015 03:27 PM
sleeperZ96BT
Sep 14, 2002 07:42 AM
