17x9.5 zr1 rims..spacers? lowering springs?
Old Feb 14, 2003 | 11:56 PM
JJJ93z's Avatar
i just got a set of the triple crome plated zr1 rims 17x9.5 , one of my buddies said i might need spacers to keep them from rubbing the wheel well when they are turned.. is this true?? also i was looking at edibach springs to lower my car b/c of the incresed wheel size, the kits claim 1.5-3" of drop, if anybody has done this in my situation your comments and suggestions would be much appreciated! thanks!
Old Feb 15, 2003 | 06:29 PM
NHSZ28's Avatar
slp has them
slp sells spacers when you lower your car and have bigger rims on it i think they cost 25$ i believe check it out at there site. How you like the snow????
Old Feb 15, 2003 | 11:00 PM
Srper's Avatar
You do not need spacers for those wheels. 275/40/17 tires will work just fine. I would go with Eibach ProKit, which drops the car 1.25/1.25 and will look good. The Eibach Sportlines are even lower at 1.75/1.75. Looks more aggresive, but is real low. Check my pics.
Old Feb 16, 2003 | 10:00 AM
DrivingZiggy's Avatar
I'm running the 17X9.5 '96 Grand Sport wheels--which are basically ZR1 wheels painted black. I get a bit of rubbing in the REAR on my very steep, sharply angled driveway. I've heard that can be fixed by upgrading to a better panhard rod. Other than that, no rubbing at all.
However, I did have to take my Dremel to the "hub hole"??? because it was just a tad too tight to actually go on all the way.
No spacers.
thenewkid
Apr 12, 2015 07:42 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
High HP TA
Sep 6, 2002 08:00 PM
