Where to get Opti Sensor?
Old Feb 14, 2003 | 09:52 PM
saltydog's Avatar
Where can I get the cheapest opti?
What wires should I get?
What plugs should I use?
Thank You
Bo
Old Feb 14, 2003 | 09:58 PM
Hyperspeed97z28's Avatar
what year of your car would help on some details... do a search for "jason cromer"
Old Feb 14, 2003 | 10:03 PM
saltydog's Avatar
94 formula
lt1
Old Feb 14, 2003 | 10:11 PM
saltydog's Avatar
should i get vented or unvented????
Old Feb 15, 2003 | 07:26 AM
RamAir95TA's Avatar
Converting to the vented Opti will be a pretty big job. You need to install a cam that has the longer driveshaft dowel pin that seats on the back of the opti. You'll need to pull the intake, fuel rail, radiator, water pump, cooling fans, opti, timing cover, timing chain, valve covers, rockers and valvetrain, and then the cam.
It's a pretty big job, and only worth it when you decide to install an aftermarket cam to begin with.
Old Feb 15, 2003 | 08:34 AM
Blue89Bird's Avatar
Get an unvented
Order through Jason Cromer or Dal Slaubaugh(sp?)
Wires? OEM replacements have worked great for me and some others, it depends what you plan on doing
Plugs? Are you staying NA, if so I like the oem ones as well, going with some n2o get some NGKs.
Old Feb 15, 2003 | 05:50 PM
saltydog's Avatar
thanks guys
Ill get an unvented.
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
May 17, 2015 10:18 PM
maybe2fast
Mar 16, 2015 11:59 AM
mikey4play
Mar 15, 2015 11:45 AM
Injuneer
Dec 15, 2014 09:36 AM
