Gear Ratio on Stock Camaro, Question!
Old Feb 14, 2003 | 04:04 PM
Hummer911's Avatar
How do I know what kind of gears/rear end I have on my 99 Convertible Camaro V-6? I want to get some 3.43s and was told if I have the 3.08s I cannot get them unless I buy the differential from SLP to make my car handle the gears. If anyone knows how I find out my rear end and gear ratio, it would be appreciated and if its true I have to purchase another item from SLP along w/ the gears. Thanks...
Old Feb 14, 2003 | 06:16 PM
ImportKILLER's Avatar
Look in the driver's side door jamb for a GU(#).
Find it, post it here and someone will tell you.
I don't memerize the gear codes...others do though.
Old Feb 14, 2003 | 09:43 PM
99blackSS's Avatar
GU2=2.73 Ratio
GU4=3.08 Ratio
GU5=3.23 Ratio
GU6=3.42 Ratio
Old Feb 14, 2003 | 09:48 PM
99blackSS's Avatar
This was a few posts down 3.08 to +3.42 gears
Old Feb 14, 2003 | 11:29 PM
kahouna23's Avatar
If your car is a Y87, that makes a difference as well. If so, you already have posi and I do believe 3.43's Pretty bad I don't even know what gear ratio I have in my car......I suck!!!
Old Feb 15, 2003 | 12:50 AM
Hummer911's Avatar
GU4 IS what it says on the sticker in the door jam. So I guess I have 3.08s and that means I can upgrade to the GM Motive 3.42s without having to add anything else from LSD or anyone right?
How do I find out if its y87? I know the birds have the body kits on the y87s but my convert looks just like all the others..for now :-)
Old Feb 15, 2003 | 12:56 AM
Hummer911's Avatar
Hey kahouna23--Sweet Ride you got there. Mines a black convertible. How much did you pay for the Light Bar and whered u get it? I really wanna get one of those..You ran a 14.1 w/o doing anything major? Damn.....beating 96-2001 Mustang GTs..All you need now is a Ram Air Hood
Old Feb 15, 2003 | 04:53 AM
oil pan 4's Avatar
RPO
The Y87 will be on the inside of the door same place you will find your GU#.
Old Feb 15, 2003 | 12:36 PM
kahouna23's Avatar
Actually Hummer911, I had quite a bit of mods done to the car. My CarDomain page hadn't been updated then. I ran a 14.3. Stock GT mustangs don't really give me much of a challenge, but if their modded....they walk me. I don't mind loosing once in a while. As for the light bar, I got it at RkSport for $500 and some change. Installed it myself, that saved money too. It's not hard at all. You'll have to send me some pictures of your car. I'm anxious to see another convertible. Doesn't seem to be many around on the board. Take care.
Ram air hood.....yeah
Old Feb 15, 2003 | 01:48 PM
MustangEater82's Avatar
jsut as a tip if you do upgrade tyo 3.42s, i woudl get Limted Slip differential(LSD), its not that muych more expensive, and actually woudl be cheaper if you did it all at the same time.
it will help you launch better, and in the long run you will, love how it feels coming out of corners and such...
besides tswo wheel burnouts are much beter then 1 wheel burnouts.
Old Feb 15, 2003 | 03:04 PM
nothingeined's Avatar
definately get 3.42's. my car has em and i did not really notice till i drove my friends 3.08. off the line it sucks. with the 3.42's, most of the time i get good launchs with no tire spin at all or loss of control. i would definatley upgrade.
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
