52mm TB....Holley vs. BBK
Old Feb 13, 2003 | 04:35 PM
CARGASM's Avatar
Which one is considered better of these two throttle bodies?
I have heard of a few fitment issues regarding the holley but thought it a good idea to ask first.
Let me know your experiences with them good/bad.
~Adam M.
Old Feb 13, 2003 | 04:44 PM
BUBBA's Avatar
AS&M. No contest.JMHO.
Old Feb 13, 2003 | 07:36 PM
mojo's Avatar
I had a 52mm BBK,sold it and bought a 58mm Holley-the BBK doesn't look as nice as the Holley,but for the money it was a better TB-don't waste your money on the Holley.
Old Feb 13, 2003 | 07:46 PM
Beast96Z's Avatar
Having seen and delt with both, the fitment issue of the holley is almost non exsistant. If you have to modify anything it won't be much. The bbk whistles really bad. Makes it sound like you have a supercharger or something. That can be fixed by grinding on something in there. When it comes to it, the Holley looks better, but is more expensive. Both have minor drawbacks, but more or less comes down to looks. If you like shiney stuff, get the holley, if you want a stock look, get the BBK.
Old Feb 13, 2003 | 07:50 PM
Ken95Z28's Avatar
Why not get yours ported to a 52mm.
Just does not make since to spend that type of money on one unless you are going to a 58mm.
I picked up one for $215 than when I return mine to them I will get $30 back, total cost $185
Old Feb 13, 2003 | 07:57 PM
stik6shift93's Avatar
Yeah the finish on the inside of my BBK throttle body sucks. It looks like they ported it out with some 40 grit sand paper. Nothing a little dremeling didn't take care of but i shouldn't have had to do it in the first place. Other than that everything fit fine.
CARGASM's Avatar
Ken95Z28: can I get some more details?
Has anyone else done this?
As much as I like shiney things, I prefer things that work well and as expected, so I still am not sure.
Keep the opinions coming!
~Adam
Old Feb 14, 2003 | 06:58 AM
IDOXLR8's Avatar
Personally I would go with AS&M but if your heart is set on Holley & BBK then I would go Holley
Old Feb 14, 2003 | 08:19 AM
Ken95Z28's Avatar
~Adam
Sure thing, I found a guy on Ebay and talked to him about his TB's that he takes the 48mm and makes them 52mm.
This is the one that I'm getting.
52mm TB
I talked to him a couple of times and found other people that was using his TB's and is very happy with them.
Old Feb 14, 2003 | 09:38 AM
NOMAD's Avatar
Cool
I'll be back in business as soon as I get my CNC Then were gonna be talking high quality
-Shannon
Old Feb 14, 2003 | 10:31 AM
WheelmanZ28's Avatar
I have the 52mm BBK throttle body and I'm kinda mad that i wasted the 300+ dollars on it. The stock one is perfectly fine and will last u well up to 400 HSP (if u even plan on going that high)
When my TB was installed, I had a lot of problems with the throttle linkage sticking at certain points and the car would often idle as high as 1800 RPM. u would have to tap the gas a few times to knock it back down to the set idle position.
Old Feb 14, 2003 | 11:07 AM
RealQuick's Avatar
I had that problem as well. I installed it in 30 degree weather, but I havent driven it since. If it keeps sticking, what can be done?
Old Feb 14, 2003 | 11:18 AM
ddr698's Avatar
I had bought a bbk 52mm and never installed it as a found a ported stock i liked better. But when i sold the BBK the buyer emailed me back after having the same problem. I had no idea anything was wrong with it but i guess he said that the rod that holds the throttle body blades wasn't connected right to either the spring or the part where the cable connects, im not sure where the problem was but it was in that area. I know he said he had a welder fix the problem and it works fine now. I wish i could be of more help but i never got to see where the problem was as it was in new york by that time. Thought id mention it,
Dan
Old Feb 14, 2003 | 12:22 PM
dlx3200's Avatar
Thumbs up
I have a BBK and never had any problems with it, Mine don't make any noise at all.I did hear some people say theirs did but mine's fine.
Old Feb 14, 2003 | 12:32 PM
WS6T3RROR's Avatar
I had lpe do mine. he had a deal going a couple of years ago i guess. it didnt cost me much around 180 shipped and all but i had to return my stocker the core charge was retarded. i've had no linkage troubles or any idle problems. virtually invisible change day to day use.
truecontr3
Oct 11, 2015 09:30 AM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
colts0455
Sep 2, 2015 12:41 PM
colts0455
Jul 24, 2015 04:51 PM
