Test the PCV valve?
Old Feb 12, 2003 | 09:33 PM
Mikey97Z's Avatar
Question Test the PCV valve?
I noticed that a lot of oil was coming into my throttle body from the vent tube on the passenger's valve cover. The air should be travelling in the other direction. Does anyone know how to test the health of the PCV valve?
Old Feb 12, 2003 | 09:39 PM
Buttercup's Avatar
Actual the system flows both ways depending on engine vacuum, gotta get rid of blowby at WOT too! The simple test is to remove the valve and give it a shake, if it rattles it's good. You can clean it out with some solvent. The valves are so cheap it wouldn't hurt to try a new either.
lt1matt
Mar 21, 2015 07:35 PM
grgguy
17
Feb 23, 2015 07:57 PM
