Which setup- 2 12" Punch's or 3 10" JL's...both in a box?
Old Feb 11, 2003 | 07:57 PM
sfGi8nt's Avatar
Just wondering which would sound/knock better?
Also...what kind/size amp would I need for both setups?
Tahnks!
Old Feb 11, 2003 | 08:01 PM
BigTymer's Avatar
Re: Which setup- 2 12" Punch's or 3 10" JL's...both in a box?
Tahnks!
Which Punches? and Which JL's? Sealed? Ported? How much room do you have to work with?
Old Feb 12, 2003 | 10:01 AM
jkayner's Avatar
OR 1 12" JL W3 sub. The W3's have a long excursion, so the airspace they move is alot. The 1 W3 sub i have now sounds just as good or better than the 2 w0's i had previously, plus the room i saved is alot. (1.25cubic feet instead of 3 cubic feet). I'm running ~200 watts to the sub and it sounds very good. The sub will handle more than that, so if you want you can use more power for it to get more bump.
Old Feb 12, 2003 | 10:18 AM
firebirdude's Avatar
You call around 12mm Xmax "long excursion"??? Longer then the W0's, true, but only by about 3mm!!! If you want some cheap long excursion subs, check out the Adire Audio Shiva or the Elemental Designs K series. Both have over 15mm and cost about $150/each.
As far as sfGi8nt's question, we need more info.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
karpetcm
Sep 29, 2015 10:08 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
