clutch questions??
Old Feb 11, 2003 | 03:32 PM
brewski4u1's Avatar
clutch questions??
as you all can see i have a 1999 M6 and its got about 55,000 miles on the stock clutch and and i was chaning my oil and all my other fluids, but when i looked at my clutch fluid it looked like mud so i want to bleed my clutch or flush the system but i couldnt find a bleed vavle anywhere. did i miss it or is there not one? if theres not one how do you change the fluid in your clutch ??
thanks for the help
Old Feb 11, 2003 | 07:21 PM
stik6shift00's Avatar
i dont know much about it..ill try to get a friend on that knows alot about that stuff.
Old Feb 12, 2003 | 12:15 PM
brewski4u1's Avatar
so i'm assuming that there is no way to bleed the clutch lines? then how do you fix a mushy clutch ?
Old Feb 12, 2003 | 12:34 PM
stik6shift98's Avatar
yes you can bleed the system...thats what i have to do.....
Old Feb 12, 2003 | 01:37 PM
stik6shift93's Avatar
stik98 I believe he was referring to the actualy trans fluid, not the fluid in the hydralics.
Old Feb 13, 2003 | 12:26 PM
brewski4u1's Avatar
Naw i'm reffering to the actual fluid in the hydrolic lines, how do you bleed them?? is there a away?? i reall need to know ?
Old Feb 13, 2003 | 02:15 PM
Sorry my mistake, unfortunatly I dont know the ansewer to your question. Try doing a search, I'm sure this topic has been brought up before.
Old Feb 13, 2003 | 09:43 PM
M3EATER's Avatar
The bleeder is ABOVE the the hose quick disconnect at the rear of the bellhousing.
See the picture:
Almost impossible to get to.
You'll need a 1/4" drive ratchet & short socket (I can't remember what size... 12mm maybe) and a 2 foot long piece of clear vinyl hose 1/2" in diameter (3/8 would be a better fit but you can't slide it on the bleeder with the tips of your fingers) ... or if you can get 7/16, you could try that.
Anyway, it's a pain & a mess. DO NOT pressure bleed it. You'll run the chance of blowing fluid from the threads where the bleeder screws into the slave & getting it on the disc ........yeah, go ahead & ask me how I know.....
Gordon
www.provenperformanceconcepts.com
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
