Linear rate springs.
Old Feb 11, 2003 | 10:33 AM
dfw_z28_jay's Avatar
Does anyone have any experience running stiff, linear-rate springs? Picked up another Z after my last one. Car is a '95 m6 completely stock, and I'm looking to make it a handle respectably.
I want to start with springs/shocks, but am only able to find progressive rate springs. I saw an offering from Suspension Techniques that was linear rate, but only for the front. Maybe I'm off on my thought process, but I want a stiff ride that's always tight.
Is progressive not as bad as I'm thinking? Any help is appreciated.
Thanks.
Old Feb 11, 2003 | 04:08 PM
Soma07's Avatar
Progessive isn't bad but linear makes it easier to setup the shocks.
Anways the Eibach Pro kit for LS1 cars uses a linear front spring (400lb/in) but the rear is still progressive (80-113lb/in).
Old Feb 11, 2003 | 04:10 PM
Dr.Mudge's Avatar
I have a set of rare, and now discontinued ST springs with straight rate fronts. 600# fronts and 140-160# rears, they are a tad low, but they work great with the Koni doubles.
I've seen only one other set on eBay once, they are blue, but you are more likely to find thier 430# fronts and dont know the rears on that setup.
There is always coil overs, I'll get some eventually.
Old Feb 11, 2003 | 05:54 PM
lt1form's Avatar
I believe LG Motorsport springs the fronts are linear, I believe 548 pound spring rate but the rears are progressive.
Old Feb 11, 2003 | 06:33 PM
SStupid's Avatar
G2
Check with G2. They used to have linear-rate springs.
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
karpetcm
Aug 14, 2015 03:02 PM
Aug 5, 2015 08:35 AM
