385 and 700 swap! have questions
Old Feb 11, 2003 | 08:42 AM
CR0067's Avatar
First off I`m new to the board, I have a few friends here who are on the board, so I figured I would join. OK first question is I am clearancing my block for the rod bolts, just curious how much metal can I grind off the block before hitting a water jacket. I have the Eagle esp h-beam rods w/through bolts, will I need to take a little off the bolt head itself, and also should I have any problems w/cam interference, the cam I have is a lunati bracket master adv.duration 300/300 at .050 246/246 lift 515/515. The final question I have has anyone encountered any major problems swaping in a 700 in the place of a turbo 350, I have all the improved internals for the 700 that I got from bowtie overdrives, all suggestions welcome!
Old Feb 11, 2003 | 09:42 PM
Zoomin's Avatar
Welcome to the board! I can't help you with the clearance question, but on the 700, you can get a th400 crossmember and elongate the holes to work and drill only a couple of new holes in the frame. The drive shaft will have to be shortened, you'll have to figure out a way to get the convertor to lock up, rig up a cooler because they hate heat, get some new detent gates for your shifter, and rig the TV cable just so. Other than that, no problemo!
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Red_94Formula
Jan 22, 2015 12:17 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
