Knock knock....whos there???
Old Feb 10, 2003 | 07:06 PM
RedRyder518's Avatar
It was brought to my attention today about a wierd noise coming from my engine. When the car is idleing, there is a light knocking noise, seems to be coming from the center of the engine( like not from one particular side). It seems to dissapear when throttle is added, but it may just been droned out from the engine noise. If it matters, they are origional spark plugs on the car with 71k miles. Thanks!!
Old Feb 11, 2003 | 06:41 AM
IDOXLR8's Avatar
I would recommend getting new plugs and wires and see if that helps any.
Old Feb 11, 2003 | 09:20 AM
I really hope its nothing related to the engine. At 45k miles, the engine was replaced under warrenty at a dealership. There was nothing wrong with the engine, but the man I bought the car from worked there and just wanted to have a new engine. The thing I dont understand is why they would put the origonal spark plugs back in...
Old Feb 11, 2003 | 09:23 AM
IDOXLR8's Avatar
You also may want to drain your oil and make sure there is no metal shavings in the pan. Is the knock you are hearing loud??
Old Feb 11, 2003 | 07:11 PM
When I was leaving school today, my SES light came on. Took it to autozone and had it scanned. I cant remember the exact code, but it was the O2 sensor heating element malfunction. The code came on when my car was cold so I suspect it is probably for real. Don't know if this is any realavence to the knocking, which by the way isn't too loud, but noticeable. I'm probably just being **** and overly paranoid about my car since I don't have a lot of money to fix it....
Old Feb 11, 2003 | 07:37 PM
DubbyZ28Camaro's Avatar
LT1's do also have exceptionally loud fuel injectors...put a screwdriver on the fuel rail and listen to the butt of the screwdriver. If you hear the knocking, thats where your noise is coming from...if not, it looks like you have other issues sorry to say...
Hope this helps...
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
