Are stock 3.42's enough for cc306??
Old Feb 10, 2003 | 03:30 PM
Robbie's Avatar
Or should I get 4.10's first?
Old Feb 10, 2003 | 03:40 PM
Dr.Mudge's Avatar
If you can tune the car 3.42s are fine, I haven't replaced my gearset yet. If your tuning is a bit off though or torque is missing, dont expect to use 6th gear without breaking the law.
Old Feb 10, 2003 | 03:48 PM
6Speed's Avatar
Yeah, you can keep your stock gears. I'm running a pcm4less tune, with the stock gears and the 306. I can still run 55mph in 6th gear, no problem. The only problem I have...and I don't think this is gear related...is that my car jerks and surges when I'm sitting right at 1600-1700rpms. Anywhere else, it drives fine. Guess I'll have to try VEmaster.
Old Feb 10, 2003 | 04:21 PM
chesee48's Avatar
Those should be fine, but then again if u think about it, 3.73's may not be worth the jump, so you have the right idea, either keep yours or go with 4.10's.
Theres people with both..
Old Feb 10, 2003 | 04:24 PM
Dr.Mudge's Avatar
I could do low RPM with a big cam too, but I dont like the idea at all. If we had L98s that were doing 440 RWTQ or something that might be different. I want to make sure I have some oil pressure going, and with that in mind I'd go for some gears eventually or run in 5th gear when traffic gets crappy.
Old Feb 10, 2003 | 05:24 PM
Buttercup's Avatar
I could drive my car with the 3.42 and a cam, but I was always yearning for gears.
1.) You have to slip the clutch more to get a smooth standing start on the street with 3.42.
2.) Steeper gears put you into the powerband of the cam quicker than the 3.42's.
I drove with a couple of different cams on the 3.42 gearing without headache but I'm glad I finally worked up the courage to install the 4.11's. I will say that proper tuning helped immensely with those standing starts. Now I just constantly worry about breaking the 4.11's
canbaufo
May 25, 2015 12:01 PM
blac94Z
Mar 6, 2015 07:55 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
cmdeshon
Dec 27, 2014 10:06 AM
x7x7
Aug 15, 2002 06:49 PM
