What is your oil pressure at idle?
Old Feb 10, 2003 | 12:06 PM
TLyden316's Avatar
Question What is your oil pressure at idle?
What is your oil pressure at idle when your engine is warmed up? Mine is a little under 20 psi. Is this too low? I have a 95 Z with 5w-30 Moblie 1 synthetic. Thanks for any help.
Old Feb 10, 2003 | 12:08 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
same car, same oil, same pressure here... think your good
Old Feb 10, 2003 | 12:19 PM
n2ceptor's Avatar
same oil and Pressure here too
93Z Will
Old Feb 10, 2003 | 12:32 PM
94Z & 96SS's Avatar
The 94 is alittle over 20 PSI but the 96 is between 30 and 40 at idle.
Old Feb 10, 2003 | 12:41 PM
Patman's Avatar
With the oil fully warmed up and the transmission in drive, I see about 18psi on the gauge.
M6 cars should see a higher idle oil pressure since their idle speed is higher (800rpm vs 550 for the A4) Their oil pressure at idle should be closer to 30psi.
Old Feb 10, 2003 | 12:53 PM
Severous01's Avatar
have a 97 lt1 and im runnin' royal purple with ~25 psi. well over 50 when at 4k rpm. i dont push her over 4k that often.
Old Feb 10, 2003 | 12:59 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
My M6 95 Z fully warmed up runs a little under 20 psi also. I think we are good.
Chris
Old Feb 10, 2003 | 03:50 PM
FreByrd2's Avatar
96 LT1 M6 - 5w30 and when warmed up or hot, my pressure reads a little below 20.
20w50 for roadracing oil press reads a little above 20 at idle when warm/hot.
jason
Old Feb 11, 2003 | 02:39 AM
Laymaster's Avatar
My M6, when it's all heated up, is about 35 or 38PSI @ idle.
Old Feb 11, 2003 | 05:49 AM
Derrick Redd's Avatar
I've got 20psi also. Your fine.
Old Feb 11, 2003 | 09:16 AM
dabear95's Avatar
That poor car, it doesent get to have any fun!
Jason
Old Feb 11, 2003 | 09:22 AM
Severous01's Avatar
only when some riced out vw or honda pulls up next to me, but i live in nj. everyone i see has a sweet ride like a lexus or a beater car with the exceptional few.
Old Feb 11, 2003 | 10:52 AM
2MCHPSI's Avatar
The average idle PSI is 22 for most Lt1 F-bodys... 20 PSI is fine.
Old Feb 11, 2003 | 11:02 AM
mebanditws6's Avatar
What weight of oil do you run?
Jason
Old Feb 11, 2003 | 11:11 AM
TMDZ28's Avatar
same goes here...
