Cloyes installation ?????
Old Feb 10, 2003 | 11:20 AM
MYT30TH's Avatar
Question Cloyes installation ?????
Are their any tips/installation guides for installing a roller chain for our car's............ did a search did'nt find much info.
Thanks,
Bill
Old Feb 10, 2003 | 11:33 AM
Ken95Z28's Avatar
I had to clearance about 30 thousands of an inch on the back side of the timing cover. Do a trial fit (without the gasket) to see if its rubbing on the chain. Also you will have to plug the hole up on top where the water pump shaft cam through.
Water Pump Shaft Removal
Look on that page that I listed above about removing the shaft and plugging up the hole.
I wished I took some pics of the place where I had to do the clearancing for the chain. It might not be the case for you but I had to do it for mine. I took a high speed (air powered) round sander and grounded down the area.
Nov 18, 2023 07:21 PM
Sergio
Jan 27, 2016 04:27 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
