Timing sets and covers
Old Feb 9, 2003 | 06:58 PM
95loveaffair's Avatar
Tommarrow I'll be ordering my new opti and water pump. I was thinking about replacing the timing chain for insurance, I have 145,000 miles on it. I've done some searches already and it sounds like a Cloyes double roller set can be ran under the stock timing cover without modifying? But then I've read that an electric pump needs to be ran with this setup??? Can some one offer some advise/clarity here please. I need to mention also I have a 95 LT1.
Old Feb 9, 2003 | 07:05 PM
I believe you cannot keep the mechanical drive for the water pump because the Cloyes does not have the means to drive the gear for it.
Old Feb 9, 2003 | 07:31 PM
SnkEatr's Avatar
Shoe box is right the cloyes double roller will not drive your water pump gear, and it also needs to be removed, as the cloyes will interfere with it. Also for your own information on 96-97 cars you cant run the cloyes and keep the crank position sensor, the reluctor will also have to be removed. and that would necessitate a switch to OBDI PCM. Exactly what I am doing.
Old Feb 9, 2003 | 07:32 PM
Thanks Shoebox. I think I do remember reading that somewhere now. But it will still fit under my timing cover, right? I guess then I'd need to deal with the hole for the drive then that would be left.
Old Feb 9, 2003 | 07:36 PM
My connection is too slow here. I see the answer to my next question. Tx-SnkEatr
Old Feb 9, 2003 | 07:40 PM
SnkEatr's Avatar
Yeah just get a freeze plug that size, or use some redneck engineering, I've seen a couple of washers on a bolt and nut with permatex used too.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
