How long does it typically take to install spark plugs?
Old Feb 9, 2003 | 06:11 PM
therealmagyver's Avatar
I've change many spark plugs in my time for Ford to Hondas. I need to know how long it's going to take me to install new plugs on my 98 LS1. Any tips you guys can give me would be appreciated. Tell me which plug is the hardest, so I can do it first. Any tool out there that will help? I've seen this one socket wrench at PEP BOYS that is pretty neat. Well I need to know, soon...getting NX kit install Friday morning, so if it's a 2 hour job I will do it that day, before I head to the track.
Old Feb 9, 2003 | 06:14 PM
SpecForceZ28's Avatar
probably 2-8 hours.
Old Feb 9, 2003 | 06:35 PM
stik6shift98's Avatar
i did mine like 30 mins a day 4 a week...
it takes 4 ever
stik6shift00's Avatar
forever...i helped my friend stik6shift98..OMG it takes forever to get the back ones done....no joke good luuuck
Old Feb 9, 2003 | 07:08 PM
DAM!!! I guess I can forget the track this Friday unless I do 2 a day and start tomorrow!! Oh well I guess it's better that I don't rush to the track anyway. What is the gap I need for a nitrous setup? And what plugs are you guys using for that?
Old Feb 9, 2003 | 07:16 PM
ngk tr6....gapped at 1 inch ...the same size as stik6shift93's pp....
lmao....jk
i have mine gapped at .045 ngk tr6
Old Feb 9, 2003 | 07:21 PM
stik6shift93's Avatar
Thats real cute, you only wish your gap was as big as mine. That girl said you had a small gap a really small gap.......... On your spark plugs of course
Old Feb 9, 2003 | 07:48 PM
one wicked element's Avatar
Took me about 6 hours. The driver side is about a 1 hour job, and the front 2 passenger ones were also quick, but the back 2 took about 3 hours each. Get ready to kill a day, and have band-aids ready. You'll probably have to jack the car up, and get it from underneath for the last one. HUGE PITA.
Old Feb 9, 2003 | 07:51 PM
oh ya bandaids....my hands were dead...and they were black too....
the 8th one which is the last one on the passenger side was horrible i spent 4 ever and then one day i came in and in came out within 5 mins
Old Feb 9, 2003 | 10:26 PM
dkeers's Avatar
I made a post back when I changed mine because posts like these almost scared me into taking it somewhere and getting it done. There is no way it should take over two hours.
The drivers side is about a 20-30 minute job. Just take off the AIR tube and pull the wires completely off and all of the plugs are easy to get to. On the passenger side, take off the AIR tube and nothing else. You can get the first three plugs out fairly easy. If your forearms aren't huge you can get the rear passenger plug from the bottom easily. Use a long flathead screwdriver to stick under the plug boot and twist it to pop the boot off. Reach up and put your socket on the plug and then put the wrench in the socket. This plug took about 30 minutes including jacking the car up.
You may want to bend the heat sheild by the cat so it doesn't cut you so bad. Also, some very short extensions or an adapter (one size drive to another) will come in handy when you can't reach w/ no extension, but a two inch extension is too long.
The part about cutting up you hands pretty bad is true BTW. A friend w/ skinny forearms might help too.
Old Feb 9, 2003 | 11:21 PM
ya the rst time around it takes 4ever....but now i bet i could do it in a couple hours.....
dont be scared youll be fine
Old Mar 3, 2003 | 03:22 PM
Skip Glide's Avatar
One guy on the other Z28 site you can do em all from the top in about 2 hrs. He said the secret to the psngr side was to remove the air tube and the coil packs.
Another guy said to remove the starter and lift the engine - about 20 minutes.
I haven't done it yet, but plan on investigating the possibilities when I replace the clutch and hydraulics since I'll have the starter out.
Old Mar 3, 2003 | 03:56 PM
ya well frst time it alwayds takes 4 ever....now i can do them within 3 hrs for sure
Old Mar 3, 2003 | 04:15 PM
ExMustangOwner's Avatar
Is there a guide anywhere? I'm changing mine for the first time because I just installed my nitrous kit. (havn't used it yet because I need the copper plugs in)
Old Mar 3, 2003 | 09:01 PM
Camarocks's Avatar
Is plug access bad on C5 LS1s too, as well as LS1 Fbodies? How is it compared to LT1 plugs?
