Those with BMR Relocation Brackets...
Old Feb 9, 2003 | 12:08 PM
Ernster500's Avatar
Question Those with BMR Relocation Brackets...
Hey Guys,
I'm putting in my relocation brackets and was trying to decide in which position to mount the LCAs. Upper or Lower...
Did you guys use the top position?
Or the bottom position?
And why?
My car is lowered with Jamex springs giving it about a 1.5 inch drop in the rear.
Thanks, in advance!
E
Old Feb 9, 2003 | 02:14 PM
Ernster500's Avatar
Anyone?
Old Feb 9, 2003 | 02:17 PM
All_Z_Way's Avatar
I used the lower mounting holes. I understood that any car lowerd should probably use the lower holes. Don't know that for fact though.
Old Feb 9, 2003 | 02:18 PM
bad95z28's Avatar
the lower holes are supposed to make you hook hard but they also give a stiffer ride. i can't remember which i used but i remember i had a hard time getting the bolts to line up.
Old Feb 9, 2003 | 02:24 PM
Ernster500's Avatar
Cool.
Thanks for the input guys!
I'll go with the lower then...
Old Feb 9, 2003 | 02:57 PM
Z28ROC's Avatar
All the way to the bottom would be best for a lowered car.
Old Feb 9, 2003 | 03:11 PM
aircop40's Avatar
hey whats up buddy, yeah if you car is lowered i would def. go with the lower holes. i put mine on the lower ones and yeah i have heard the same, supposed to hook alot better but gives ya a stiffer ride supposedly! lata
Old Feb 9, 2003 | 05:32 PM
You want the LCA to be parallel to the ground (comparable to stock) or lower at the rear end housing than at the body mounting point. By all means, avoid lower on the body end.
Old Feb 9, 2003 | 07:08 PM
Ernster500's Avatar
Thanks for the advice, guys!
I'm almost done with the install. Now I just gotta put my PITA brake calipers back on. I took them off, cause I painted them while installing everything else...
football4life
Oct 4, 2015 07:48 AM
JJOHNROE
Sep 8, 2015 05:39 PM
97blackformula
Aug 27, 2015 06:02 PM
TGGodfrey
Aug 18, 2015 06:08 PM
realistyc
Jul 28, 2015 07:32 PM
