perge kit
Old Feb 9, 2003 | 11:27 AM
RichardFnRamos's Avatar
perge kit
Ok i have a -4an line nitrous kit. There is this perge kit for sale for a good cheap price but its for a -6an line. Is there any way you can use an adapter of some sort or is it even possible to do that, to get the them together.
Old Feb 9, 2003 | 11:48 AM
On the NOS purge kits, they use a "gauge adapter" fitting inserted in the main line, to allow the solenoid to be connected to the 1/8" NPT outlet on the side of the gauge adapter. All you need to do to make the -6AN NOS purge kit (PN 16032) into a -4AN purge kit (PN 16030) is to buy a -4AN gauge adapter. In the NOS line, you would need PN 16770, which used to be about $8, but is probably more expensive by now. Earls probably makes something similar.
If its another brand kit than NOS, it may require different fittings.
Old Feb 9, 2003 | 11:54 AM
Thumbs up
Alright ill check that out. Thanks alot man.
Old Feb 9, 2003 | 12:00 PM
Hey at www.summitracing.com part number NOS-16770 , are you talking about that kind?
Old Feb 9, 2003 | 06:09 PM
stik6shift00's Avatar
i havent heard of it...but i would think it should work
Old Feb 9, 2003 | 09:31 PM
Well we will have to see when i order the little piece.
Old Feb 9, 2003 | 09:54 PM
RacinLT1's Avatar
that is exactly the part you need to make it work with the standard nitrous lines.
Old Feb 9, 2003 | 11:03 PM
stik6shift98's Avatar
for the purge some people use brake line...
Old Feb 10, 2003 | 12:16 AM
Originally posted by Injuneer
....In the NOS line, you would need PN 16770.....
Originally posted by RichardFnRamos
....Hey at www.summitracing.com part number NOS-16770 , are you talking about that kind?...
Not sure how it could be anything but the correct part... the Summit part number indicates it is made by NOS, and that it is part number 16770.
And your point is????? .
Old Feb 10, 2003 | 12:52 PM
hey i posted that not stik00 come on your a moderator you should know jk
i was just saying why get all that nitrous special line when u can get cheaper lines.....thats all
Old Feb 11, 2003 | 06:44 AM
k thanks thats all i needed to know. Now im just waiting for the part to come in. Woo hoo.
Old Feb 11, 2003 | 07:40 PM
get the duel purge set up..that looks awesome
Old Feb 12, 2003 | 02:08 AM
duel stage eh .. Isn't there a way that you can split one into duel perge?
Old Feb 12, 2003 | 07:42 AM
RacinLT1's Avatar
You can make a dual outlet purge with 1 solenoid,just takes a T fitting and tubes for the purge outlet,do a search,we explained a few different weays on how to do a while back.
Old Feb 12, 2003 | 09:01 AM
i think you can also get the nozzle from nx.....or just split it with a t as stated above
