I got a quick OBD1 doesn't like big stall TC question.
Old Feb 9, 2003 | 12:48 AM
Kain's Avatar
I think I'm getting my stuff figured out.
My car doesn't like to shift if I floor it from a roll. From a dead stop its fine.
1-2 shift really isn't a problem, unless I punch it around 40 when it shifts 1-2. Then it'll just bang into the limiter in 1st.
Say if I punch it in the middle of 2nd, it'll bang into the limiter at the 2-3 shift from a roll.
If I nail it from a stop, it'll shift fine 1-2, then go through second and it'll shift 2-3 fine as well.
I was just wondering if this was the OBD1 doesn't like big stall torque converters problem at work. It doesn't really matter, I try to only race from a dead stop anyway. It's just for my clairification.
Thanks!
Old Feb 9, 2003 | 02:17 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: I got a quick OBD1 doesn't like big stall TC question.
Thanks!
sounds more like a tranny than OBD problem
OBD is only when you launch hard i think
Old Feb 9, 2003 | 02:27 AM
djcam's Avatar
i too have read somewhere that OBD1 does not do good with a big stall dont know how to go about fixing it though.
Old Feb 9, 2003 | 05:48 AM
1QUIKTA's Avatar
Ask funina91ss or blownbird355 about this. I believe it is recommended not install a TC above 3K. The OBD I has problems with this. Some people get away with it, but most don't. I heard Bryan at PCMforless found a fix that may work for some.
Old Feb 9, 2003 | 05:57 AM
ROADRAGE's Avatar
I can't remeber what it is in the trans that has to be changed, but Hot Rod Hawk would. Try messaging him.
Old Feb 9, 2003 | 07:26 AM
ucrazymonkey's Avatar
No, Bryan has found the fix. My freinds 94 Z had no problems when he was running a TCI 2800 stall. When he went to a Vigilante 3800 the probelms began a month ago. 2 weeks ago my friend was given the fix from Bryan and I watch it with my own eyes at the track. It works!
Old Feb 9, 2003 | 11:46 AM
treyZ28's Avatar
you have it backwards
some get it, most get away with it
Old Feb 9, 2003 | 12:30 PM
Kain's Avatar
Re: Re: I got a quick OBD1 doesn't like big stall TC question.
Could be. I only hit the true OBDI problem once when I flashed the converter off idle with ET Streets. It started banging into the rev limiter. I normally stall it up to around 1200 or so, then let it flash and I have no problems.
Hmmmm.
ShwaZedder
Apr 20, 2015 02:31 PM
greenzee28
Mar 26, 2015 09:13 AM
alex5366
Feb 17, 2015 09:07 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
