Whats missing in my kit?
Old Feb 8, 2003 | 08:17 PM
lt4 fd's Avatar
Ok maybe I dont know how its supposed to go togeter but Ill describe all teh pieces I have adn where I have tehm connected outside teh car and hopefully someone can tell me if its all there. BTW its suposed to be a nx wet system of some sort.
ok I have teh bottle then teh line going from the bottle to and Ice man pure-flo solenoid and out the bottom of that comes a line going to the fuel part of the N.O.S. fogger nozzle ( I know this is wrong just seeing if all teh parts are there) then next to the ice man super flo solenoid there is a smaller one that says nitrous solenoid and looks like the super flow only a bit smaller, there is a line coming off the nozzle from teh nirous part that I cant find a connection for.... besides teh pills and stuff whats missing??? Also how does it know to only turn on the nitrous at WOT?
Old Feb 8, 2003 | 10:03 PM
lt4 fd's Avatar
Its supposed to be a nx kit bought in pieces, do i have everything I need to make it work even if its not everythig that comes with teh nx wet kit purchased from their site?
Old Feb 9, 2003 | 11:48 AM
RacinLT1's Avatar
The small solenoid off the side is the purge,it can be vented out of the car,or stay underhoos for somewhat of a "stealth" gig.. The line to the nozzle does come from the bottom of the big solenoid,this goes to the N2O side.Where is the fuel solenoid at? Gotta have a full throttle switch to turn it on at WOT.
The jets go in the nozzle(as you know).
Maybe i missed something,but you dont have anything listed for the fuel side.........
Old Feb 9, 2003 | 12:24 PM
lt4 fd's Avatar
thanks man Ill talk to the guy and see what else he has what am I going to need for the fuel side so I know what Im asking for?
Old Feb 9, 2003 | 12:31 PM
RacinLT1's Avatar
you need a line from the fuel rail testport to the fuel solenoid(which you also need). Then you need a line from the fuel 'noid to the nozzle,dont forget a WOT switch,relay,toggle,jets.
Old Feb 9, 2003 | 12:52 PM
lt4 fd's Avatar
Ok he has the fuel solenoid and some lines and a pressure gauge and is the WOT switch a switch you flip that has 3 prongs on teh bottom, if not whats it look like so i know.
Old Feb 9, 2003 | 01:10 PM
RacinLT1's Avatar
The switch you manually hit is the master arming switch,the full throttle switch is small/black,silver lever off the top,and 2-3 prongs,very small and narrow.
Old Feb 9, 2003 | 01:37 PM
lt4 fd's Avatar
You kind of just described both.... It is a small silver lever with 3 small and narrow prongs. I think it has a red light in top of teh lever, where does teh WOT switch go in the car?
Old Feb 9, 2003 | 02:36 PM
RacinLT1's Avatar
I described 2 switches.
The lightup handle is the master arm switch,goes in the car.
The full throttle switch goes near the Tbody.
Old Feb 9, 2003 | 06:02 PM
stik6shift00's Avatar
sounds like a good set up
Old Feb 9, 2003 | 06:50 PM
HiYaPerri's Avatar
Is everything working yet??
Old Feb 9, 2003 | 06:53 PM
ttt
Old Feb 10, 2003 | 01:02 PM
lt4 fd's Avatar
Nope I still have to pick up the stuff for the fuel side and the WOT switch which I think the guy selling it to me is even more clueless than me. What makes it sound like such a good setup?
Old Feb 10, 2003 | 05:36 PM
stik6shift98's Avatar
sweet......just wait till u install it
Old Feb 10, 2003 | 05:42 PM
stik6shiftoo's Avatar
nice set up .
