Urgent Response Needed!!!
Old Feb 8, 2003 | 03:13 PM
96 WS6's Avatar
I am in the middle of tapping the hole in my oil pan for the Vortech supercharger oil drain. It says to tap it with a 3/8 tap but from the way it looks the tap is not big enough for the fitting. Am I imagining things or will that fitting actually thread into that hole even though the hole looks a lot smaller than the fitting...
Is an NPT tap the same as a normal tap? I'm using a 3/8-16 tap.
Old Feb 8, 2003 | 04:33 PM
Brady's Avatar
You're using the wrong tap, you need a 3/8" NPT tap (Pipe Thread).
You should be able to get one at a decent hardware store.
good luck!
..Brady
Old Feb 9, 2003 | 01:21 AM
96 WS6's Avatar
I got it and completed the install successfully, thanks.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
94Form
Feb 10, 2015 11:23 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
