Question about stall conveter.
Old Feb 8, 2003 | 02:52 PM
Cerwin Vega Fan's Avatar
Question Question about stall conveter.
If I understand this right if you get say a 2800 stall converter that means the car will not move until you hit 2800 RPM's right? Well, I would like to get one since they are basic must bolt on for an automatic but I was wondering how are they for daily driving? Does taking off at 2800 RPM+ from every red light get tiring after a while? My Z28 is my daily drivier not a strip car.
Old Feb 8, 2003 | 03:12 PM
Red 97T/A A4's Avatar
The car will move before 2800 RPMs. It's just that the throttle response will be mushy.
I have had a generic 2500 stall then I bought a 2800 Vigilante. No problems here. Wish I'd gone with the 3200. (Actually ordered a 3200 but Tbyrne sent the 2800. )
Old Feb 8, 2003 | 03:41 PM
So what happens say when you reach the stall, you get better throttle or something? I mean I can cruise through town all day without even hitting 3800 RPM.
Old Feb 8, 2003 | 11:58 PM
So the stall number is not a direct relation to the number of RPM's?
Old Feb 9, 2003 | 12:51 AM
stevil's Avatar
Stall is based on RPM. But a 3000 RPM stall in your car will be alot different than a 3000 stall in a blown 396 making 500+ rwhp. In your car it would "stall" at lets say 2900 RPMs, but in the car with more power, 4100 RPMs, even though it's the exact same torque converter.
So like Pro/Street said, depends on how much power you have. I believe most TCs are rated at "near stock" levels, so that should help. The companies can also judge by how much power you have, how a TC will stall. Most companies can suggest a good TC based on your current and future mods.
Basically, you'll be revving it a little more to get it going. I think the stock TC stall speed is 1700 RPMs or something, if that helps.
Old Feb 9, 2003 | 01:25 AM
bad95z28's Avatar
a stall is a great mod. but i would recommend trying to find someone in your town that has a vehicle with a stall in it and going for a ride. it is very difficult to explain what it does. its almost like having and automatic with a clutch. except you can't control it. but then again that doesn't make much sense either.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Injuneer
Dec 15, 2014 09:36 AM
