Gonna install a shift light or tach/shift combo.....
Old Feb 8, 2003 | 01:21 AM
96Z28man's Avatar
How difficult is the installation of a shift light?? where is the best place to put it so it's not as blinding???
Old Feb 8, 2003 | 11:24 AM
Bud M's Avatar
I mounted mine at the base of the A pillar with this plastic stuff that works like velcro but has a much stronger hold. That way I didn't have to drill any holes in the dash. I routed the wire down the side of the dash and in through the fuse box cover. I found 12v and ground in the wiring under the dash and went through the firewall for the tach.
It is really bright at night but in the daytime it's perfect. I wish they made them with a circuit that was wired to the dash lights so they could dim when the lights were on.
Old Feb 8, 2003 | 12:37 PM
Grease's Avatar
I used the same material as Bud M but I monuted my shift light on steering coulmn infront ofthe speedometer. Its not on the way of anything
Old Feb 8, 2003 | 01:10 PM
96SS#724's Avatar
I have a red LED hooked up to a msd rpm switch. The LED is between the 6 and the 7 in the tach.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
