. MSD Ignition Multiple Spark Descharge Box with Rev Limiter
Old Feb 7, 2003 | 11:37 PM
Randy z96's Avatar
Exclamation . MSD Ignition Multiple Spark Descharge Box with Rev Limiter
I have a 96 LT1 I would like to go with MSD witch one do I need ?
. MSD Ignition Multiple Spark Descharge Box with Rev Limiter 6AL is this a good one ? and what coil will work?
Old Feb 8, 2003 | 12:08 AM
hvyss's Avatar
The MSD 6AL is good box. Your stock HEI coil will work fine with it. Make sure and get the harness adaptor with it. I installed a MSD 6A on my imp. I will tell you thuogh that if you are getting it for a performance gain you are wasting your money. I run naturally asperated at the track and after I installed the 6A I saw no performance gains at all. They are good but not as a performance gain, but good for a multiple spark( 3 to 1) Good luck. Just my opinion and opinions are are like a##holes everone has one and they all uselly stink.
HVY SS
Old Feb 8, 2003 | 12:13 AM
Randy z96's Avatar
Thank's man i'll spend it on headers then.
Old Feb 8, 2003 | 12:27 AM
hvyss's Avatar
Are you running a A4 or M6 tranny? I can tell you from experience headers will not give the gain you think. The first mods I did were headers and a cat back exhaust on my imp. I gained maybe 25 hp and spent 1100 dollars. I installed a stall (2400 on a A4 trans) and 3.73's and gained a half a second or more. Gears and converter are the way to go. It will cost about the same vs longtubes (700.00 aprox) and you will be much happier with the results. Been there done that Good luck
HVY SS
Old Feb 9, 2003 | 03:47 AM
Compstall's Avatar
I dyno'd my car after the 6AL install and can confirm NO gain. The factory stuff is pretty damn good. I wouldn't worry about an MSD until/if you ever get forced induction.
- Brent
Old Feb 9, 2003 | 07:24 AM
Projectz28's Avatar
Moderator
I saw no gain with mine either. The stock soil will work just fine with it. If you are looking for a HP increase I also vote to spend your money elsewhere. Only reason I have one is for the rev limiter and tach output.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
