Any good springs that dont lower? I have longtubes and little clearance.
Just wondering. Are there any aftermarket springs that will tighten up the car, and not lower it much, or should I leave the stockers on. I only have a few inches if clearance between my collecters and the ground as it is. I plan on doing the kyb adjustable shocks. Will they tighten it up good with stock springs. thanks
1LE springs are 360# rate (the stock 1st gen rate), and non-lowering.
After that, other than a coil over which you can adjust, the closest thing I know of is a .75" lowering SLP spring, 300-450# rate.
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
