383 or 396 Stroker kit?
Old Feb 6, 2003 | 07:50 PM
ChvyCruzen's Avatar
I am looking to buy a stroker kit, peferably an assembled short block. What are the pro's and con's of both?? Where would you recomend to buy one?
Matt
Old Feb 6, 2003 | 07:55 PM
Toms30th's Avatar
There's no replacement for displacement!
At least that's what I've heard. But seriously, it seems that more often than not, people seem to go with the 383. I'm thinking maybe because it's more cost friendly?
Old Feb 6, 2003 | 08:11 PM
WS6T3RROR's Avatar
about the cost thing you're right. the 383 can be made with a cast crank and the only cranks offered for a 396 (3.875" stroke) are forged. and from what i hear a 396 instead of 383 pretty much doubles the cost of the short block. not sure but i think you have to be careful on rod selection or it could hit the cam if you have enough duration and lift.
Old Feb 6, 2003 | 08:50 PM
Jim S. '95 Z28's Avatar
The only extra costs involved with a 396 are the additional costs of a forged crank (vs. cast for a 383), and some extra clearancing. Also, there are less off-the-shelf pistons for a 396, but that's about it.
For ultimate n/a power, the advantage goes to the 396.
This might help
Old Feb 6, 2003 | 09:00 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
before you do anything
"power secrets"
-smokey yunic(sP?)
or
www.cmotorsports.com
they make great 383's
Old Feb 6, 2003 | 09:16 PM
ChvyCruzen's Avatar
The little info on building strokers helps a little bit. Maybe someone can help me, I'm looking for a short block that can handle up to 6250-6500 rpms and about 450 horspower. I see from the info that I dont need a forged steel. I would like a cast steel anyways. Anybody know where I can get a 383 short block with 4 bolt mains?
Matt
Old Feb 6, 2003 | 10:09 PM
treyZ28's Avatar
Matt
look above your last post
Old Feb 6, 2003 | 10:41 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
If the banks funds allow it, go for the 396. Always nice to hear someone say there's a 396 under the hood.
Old Feb 6, 2003 | 11:01 PM
ChvyCruzen's Avatar
I wouldnt bring this up if I didnt have the funds I want to know the pro's and con's of both. I'm a daily driver and want 450 flywheel hp naturally.
Old Feb 6, 2003 | 11:06 PM
GhostZ's Avatar
Do a search for stroker on here....you'll get more info than you know what to do with.
Also contact cmotorsports, nu-tek and various other sources to see what their pricings are and what they include with their buildup.
Both of these companies offer complete shortblocks and longblocks.
Old Feb 7, 2003 | 08:07 AM
ChvyCruzen's Avatar
I know about Cmotorsports and Nu-tek, and they look awesome as well as the strokers, but I dont want a forged steel crank. Im not going to add a blower, maybe n20 in a year or so. I dont need all the fancy forged cranks, they just burn a hole in my wallet, a cast steel is all I need with an I beam. However I do want forged SRP pistons, does anyone know where I can get a short block like this assembled? I am going to contact Nu-Tek and cmotorsports to see if they can custom build a stroker for me.
Old Feb 7, 2003 | 09:08 AM
Gripenfelter's Avatar
Matt
I would go with a 383 for 450hp and that rpm range.
A 383 also allows you to use 6.0" rods.
A 396 would be overkill in your situation.
Old Feb 7, 2003 | 10:05 AM
SStupid's Avatar
Golen
Golen offers a 480hp 383 for 6800 bucks. This is the long block. Most people seem to spend plenty more than that putting their own together. I think you get a warranty with it as well. Golen has a pretty good rep, according to "Chevy High Performance."
Old Feb 7, 2003 | 10:18 AM
I get all my parts from Nick at www.nu-tekmotorsports.com
Can't go wrong with Nu-tek.
And they'll build you a stroker according to your budget.
Old Feb 7, 2003 | 10:58 AM
treyZ28's Avatar
Re: Golen
Combo motorsports
- 2 bolt main caps with ARP main studs
- Eagle 4340 forged steel 3.75" stroke crank
- Eagle 4340 forged H-Beam connecting rods
- SRP forged pistons (flat top/dish top depending on application)
- JE Plasma Moly ring set
- Clevite 77 race bearings
- Melling high volume oil pump
- Fully balanced and blueprinted
- Custom hydraulic roller camshaft designed for customer’s goals
- GM LT4 Extreme Duty timing chain set with oversized crank sprocket
- Competition Cams Pro Magnum full roller rockers
- Competition Cams chromemoly pushrods
- Ported LT1/LT4 intake manifold
- Competition Cams Pro Magnum roller lifters
- Fully assembled crate engine
$5900.00 Shipped with stage 2 heads
Thats pretty damn killer
You could easily get 450hp with that
givem a call
702 798 8504
they are also a site supporter which is a real thumbs up for me personally. I'll never buy something from a non site vendor again unless its summit or jegs.
other people will skrew you and not care.
site vendors are awesome with customer support!
and they have to be
- not to take anything away from nu-tec. I didn't hear anything bad about them yet.
