2.73 to 3.73
Old Feb 6, 2003 | 06:44 PM
blazzinbird's Avatar
2.73 to 3.73
Hi guys,
what kind of gains am i gonna see from doing this change, like times in the 1/4th and just daily driving. I know gas milage will go down i dont care. what isit going to be like driving.
i want to know all the benifits to doing this change thanks
Old Feb 6, 2003 | 06:51 PM
LimitedEd1LE's Avatar
Gears are a very important mod to do if you inted to build up the engine later. Going from 2:73's to 3:73's will be a noticable change. You will get a lot better punch off the line and a lot better throttle response. The car will bite harder. With an A4 3:73's are perfect. I assume that's what you have. Just remember that you will need to get a new diff. because the carrier for the 2:73 is different from the one for the 3:73's. SLP has the Zexel torsion diff for like $100.
Old Feb 6, 2003 | 07:24 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Thumbs up
great mod for an a4, keep in mind if you do alot of highway driving the car will rev a fair bit!
Old Feb 6, 2003 | 07:50 PM
gh0st's Avatar
I have an M6 with 2.42's(?? the lowest they came with) My gas mileage is bad as it is...when u say gas mileage will drop, how much do u mean?? like 1 or 2 mpg??
Old Feb 6, 2003 | 07:52 PM
2.42's i think you mean 3.42
Old Feb 6, 2003 | 09:56 PM
gh0st's Avatar
no...i remember it starting with a 2...maybe it was 2.73. I have no memory
Old Feb 6, 2003 | 10:02 PM
Z28BICOL's Avatar
Definitely noisier on the freeway, but great acceleration from dead stop.
Old Feb 6, 2003 | 10:51 PM
Don't Look Back's Avatar
Yeah lowest is 2.73's. I know this because I am cursed with them until I get some money. Actually, they are pretty cool, but I want 12's soooo.
Old Feb 7, 2003 | 06:43 AM
IDOXLR8's Avatar
You do not need to buy a series 3 carrier. I would just stick with your series 2 carrier and buy a 3.73 designed for that carrier. I would recommend going with a Strange gear.
Old Feb 7, 2003 | 07:15 AM
ltlhomer's Avatar
I've never heard anything bad about GM Motive gears. That's what I have and they are perfectly quiet.
Old Feb 7, 2003 | 08:35 AM
another question, will my times drop any at the track due do a lower gear.....
Im getting an eaton posi with it, strange 3.73;s welded axle tubes and rear girdle.
Old Feb 7, 2003 | 08:41 AM
IDOXLR8's Avatar
Well will probably lose anywhere from 2 tenths to 3 tenths.
Old Feb 7, 2003 | 09:20 AM
dlx3200's Avatar
Talking
I went from 273's to 410's with an a4 also. Your going with 373's so traction is still going to be a problem for you.You will like the change.
Old Feb 7, 2003 | 09:35 AM
Richmond has one of the best gears out there. They are probably one of the strongest because the teeth are not as round at the ends.
Old Feb 7, 2003 | 10:20 AM
bad95z28's Avatar
almost all gears will be good IF they are installed and setup properly. that is the key. i have GM Motive's with about 10,000 miles on them and they are quiet as can be.
Mike
