Quick LS1 rotor question
Old Feb 6, 2003 | 01:33 PM
ZDriver96's Avatar
What is the minimum thickness an ls1 front rotor can be before you cant resurface it?
Old Feb 6, 2003 | 06:31 PM
chuck's Avatar
For what AutoZone charges for replacements, I would not turn them.
Old Feb 6, 2003 | 11:40 PM
ZDriver96's Avatar
Doesnt autozone charge $39 per rotor? Or was it $49 per rotor?
Anyways its only 16 bucks to turn 2 rotors.
Is it abesolutely necessary to have new rotors or have them turned with new brake pads?
Old Feb 7, 2003 | 03:24 AM
Steve2001Z28's Avatar
I'm not sure on specs but I can tell you this,
I have had to turn my rotors 2 times in the front and once in the rear for the cost to do it next time it happens i'm just going to replace them a performance set you may want to look at the same. RKSport has some nice front ones for about $300
Old Feb 7, 2003 | 11:46 AM
rncotton's Avatar
Don't waste your time and money turning stock rotors. They aren't worth it.
Pick up some new rotors of your choice.
Old Feb 7, 2003 | 12:27 PM
ZDriver96's Avatar
Wait.. so whats wrong with turning them? Will they warp or something?
can someone go into more detail why they arent worth turning?
I can buy some barely used ls1 rotors for 40 bucks and have them turned for 16 bucks so thats 56 dollars total. Now if i buy new ones im looking at about 100 dollars.. So what am i missing here?
Old Feb 7, 2003 | 09:33 PM
stik6shift98's Avatar
get eradispeeds and you wont have to worry about this again....
its a great investement
ive had mine for about a year and their awsome
i warped 2 sets of stock rotors within 2 months.....
Old Feb 8, 2003 | 01:36 AM
dmnall's Avatar
How come it seems that a lot of people are warping their rotors ?? Could it be that they are braking too hard ?? I understand that you have to have rotors resurfaced especially when you replace brake pads/shoes (depending on year of car as well) but the main cause to have rotors warped is the fact that braking hard all the time is the cause.. Am I right or wrong on this subject ??
So far I am lucky that I have not warped my rotors on my z28 but then again not everyone has ever driven a car or truck w/ the worst possible brake system ever known to man, aka Drum Brakes.. plus especially try stopping something that is going 95 + mph, weighs around 4000 lbs, master cylinder just went out, rear axle seals are leaking, and you have 4 wheel Drum Brakes, with this combo and not even hitting anything to stop. Plus drive it home 6 miles on top of that just to park it.. I have done this and yes it was a scary event especially when you have 350 + HP under the hood and no brakes plus I did get it back home safely with no accidents.... I guess what I am getting too is try not to Brake as hard and you should not have to buy or turn your rotors in between brake jobs...
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ChrisFrez
Nov 23, 2014 10:33 AM
