Cam and valve spring Q's
Old Feb 6, 2003 | 01:57 AM
hotrod18_69's Avatar
Ok i my buddy wants me to put a bigger cam in his truck.
His valve springs are good to .500" but the cam he wants in .487"IN and .490"EX will he be pressing his luck with the cam lift being so close to the max valve lift on the springs?
Brad
Old Feb 6, 2003 | 11:17 AM
Anyone? There are a set of Double Hump heads all stock, with a alittle port job. I would say put bigger springs on, but just trying to get a second opinon.
Old Feb 6, 2003 | 11:30 AM
bad95z28's Avatar
couldn't hurt to put the bigger springs on but its not necessarily needed unless you're running a higher ratio rocker arm.
Old Feb 6, 2003 | 11:32 AM
Maldo's Avatar
Re: Cam and valve spring Q's
Brad
How many miles are on the truck?
Old Feb 6, 2003 | 11:39 AM
There is a boat load of miles on it. Its a 68 C-10 truck. We are just rebuilding the motor. But he is on a tight budget. Thats why i ask about the springs cause that would be another 200bucks he would have to save for. Spring, shims, valve locks, retainers, and then machine shop work. But the heads came from a buddy of mine, which were on a mudding truck and i think has Crane Cam Blazer springs on it.
Old Feb 6, 2003 | 01:08 PM
Maldo's Avatar
hmmmm yes that's too many miles. I have a set of lt4 hot cam springs brand new and i also have a set of used ones with about 18k on them. let me know if you want them i wil selling the stuff
cheap. I have them for sale under my friends stuff that he was selling
here is the link.
http://web.camaross.com/forums/showt...threadid=73942
Old Feb 6, 2003 | 01:27 PM
Frank95z's Avatar
If I understand correctly the heads have been rebuilt with springs good for 500 lift and you're putting a 480 lift cam in the motor. If that is the facts then yes use them if a manufacter advertises good for 500 they build in a .060 margin. So the 480 cam should have .080 before coilbind. No problem with that combo. Frank95z
Old Feb 6, 2003 | 02:22 PM
Thanks Frank that was just what i wanted to hear.
Thanks Brad
Old Feb 6, 2003 | 02:23 PM
drop top steve's Avatar
What Frank95z said, check for coil bind, retainer to guide/seal clearence and you should be ok.
Old Feb 6, 2003 | 03:05 PM
Ok great I'll be sure to check that.
Thanks Frank95z and drop top steve.
Brad
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
