Pacific Alaska, California, Hawaii, Oregon and Washington
Should I install a windage tray?
Old Feb 5, 2003 | 02:52 PM
irocz383's Avatar
most of you know already what my motor setup is like so you know I'm going to need a healthy supply of oil.
I haven't bought the oil pan yet so I'm looking at my options. Do you think its worth it to install a windage tray?
Old Feb 5, 2003 | 09:08 PM
warner's Avatar
It is cheap insurance. I'd highly recommend it as the last thing you want to suck is air. Looks like a pretty nice engine that cost some money. A windage tray costs very little.
Old Feb 5, 2003 | 09:14 PM
oldschool's Avatar
for the motor I was building for my 3rd gen, I bought a sweet moroso kickout pan and milodon windage tray...I heard it's worth quiet a bit of HP
Andy
Old Feb 5, 2003 | 09:51 PM
blue 79 Z/28's Avatar
yup, id go for it
Old Feb 6, 2003 | 12:32 AM
Charles9c1's Avatar
Thumbs up
Everything I have read indicates windage trays are a benefit. On second gens the trick set up is the early Z-28 pan with baffle and then adding the windage tray. Most guys don't think about improving this part of the system on their car. Also have read mixed opinions on the need for high volume oil pumps versus benefits. High pressure/volume pumps can push more oil than required to the top of the engine where it is not as required and use horsepower. Read "how to hot rod your small block chevy" and Grumpy Jenkins books. They have some great basics in there. I'd do it.
Old Feb 6, 2003 | 11:25 AM
CoryM's Avatar
Windage trays are "free" horsepower. Meaning that there is no drawback to using them. I definatly suggest you use one. As for the Z28 pans I am not sure if they are still available or not. I was looking for one last year a bit. Last thing you want to do is run out of oil at 6000rpm. They also keep excess oil of the crank which helps make it lighter and stay balanced (which is where you gain the power).
CoryM
Old Feb 6, 2003 | 12:37 PM
irocz383's Avatar
Thanks guys. Looks like there's another part to add to the list.
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
adam85
Parts Wanted
Jan 1, 2015 02:24 PM
ddr698
Dec 31, 2014 09:16 AM
