Howd I do on these Prices (Heads/Cam)
Old Feb 4, 2003 | 09:46 PM
jonaddis84's Avatar
Stage 1---------~~380rwhp
1. Heads and intake port and polish $ 350.00
2. Comp Cams Xtreme 224/230 @ 112 lsa $ 215.00
3. MAC Shorty Headers w/offroad Y-Pipe $ 150.00 (used) $450.00 (new)
-1200' Paint for Headers $ 8.00
4. Comp Cams Magnum 1.6 ratio roller tip rockers $ 50.00 (used) $179.00 (new)
5. Comp Cams dual valvesprings 986-16 $ 79.99
6. Comp Cams spring seats 4770-16 $ 27.99
7. Comp Cams retainers 740-16 $ 47.99
8. Comp Cams 10' Superlocks 611-16 $ 19.99
9. NGK Spark Plugs TR-55 $ 16.00 (8)
10. Intake Gaskets Fel-1284 $ 12.99
11. Exhaust Gaskets GM 12552469 $ 12.00
12. Timing Chain GM 10128485 $ 25.00
13. Timing Cover Gaskets Fel-45953 $ 7.00
14. Opti Seal GM $ 2.00
15. Banjo Bolts and washers GM $ 5.00
16. Oil Pan Gasket Fel-OS34500R $ 18.00
17. Head Gaskets GM 12553160 $ 35.00
18. Black RTV $ 4.99
19. PCMFORLESS do-it-yourself (free updates) $ 170.00
20. LT4 Knock Module GM 16214681 $ 25.00
21. Valve cover gaskets Fel- $ 12.99
Total $1286.94
Old Feb 4, 2003 | 10:10 PM
white97T/A's Avatar
what kind of porting and polishing are you getting for $350?
Old Feb 4, 2003 | 10:41 PM
Grease's Avatar
Especially the kind that makes 380rwhp with a 224/230 cam and Mac shorties They'll put every other head ported out of business. I don't see valves in your list so I'm assuming thats with stock valves.
Old Feb 4, 2003 | 10:45 PM
Can I make a suggestion? Get new cam and crank gears to go with the new timing chain. The gears will have worn to the old stretched chain and will not perfectly mate with the new one. I have always replaced the timing chain and gears as a set.
Old Feb 4, 2003 | 11:41 PM
jonaddis84's Avatar
That was an approximation a long time ago, I know it wont be very close to that, maybe 350 or 360, it is a guy that builds race engines, hes doing everything you can do without increasing valve size.
Didnt know I should have replaced the gears shoebox, hopefully they are alright, cuz I really dont want to tear into there again.
Old Feb 4, 2003 | 11:56 PM
It'll live. Just one of those things I prefer to do. Didn't realize you were done already.
Old Feb 5, 2003 | 12:12 AM
jonaddis84's Avatar
What you guys think my best guess is for power, not so much hp high end, not what im looking for, but max torque, I know this cam is a really good low end torque cam. If my starting point is 280hp/311tq at the wheels, that was with nothing in the list above. Approximate numbers, Im guessing around 350 or 360 for both hp and tq
oldschool
Feb 9, 2016 09:21 PM
Fastbird93
Sep 29, 2015 04:05 PM
MadMav
Jun 15, 2015 09:51 PM
F(ast)-body
Feb 26, 2003 09:05 AM
