Which Is Bigger Cc305 Or Hotcam???
Old Feb 4, 2003 | 09:02 PM
z28ponyeater's Avatar
Question Which Is Bigger Cc305 Or Hotcam???
just wanted to see which is bigger.
Old Feb 4, 2003 | 09:10 PM
Rodrigues's Avatar
cc305 is bigger than the hotcam...
Old Feb 4, 2003 | 09:50 PM
Cory_SS's Avatar
305 = 220 / 230, .510 / .510 114 LSA
LT4 = 218 / 228, .492/ .492 w/ 1.5 rockers, .525/.525 w/ 1.6 - both w/112 LSA
Go bigger!
Old Feb 4, 2003 | 09:54 PM
FastZinTennessee's Avatar
If you step up to 1.6 roller rockers with a 305 it ends up being .544/.544 lift. You'd want to do the 1.6s with either one I would think.
John
Old Feb 4, 2003 | 09:56 PM
94z'sson's Avatar
i would go CC305 my friend has it (cant say name) but he is running a 10.95sec in 1/4mi with a 150hp shot on a 95 lt1 t56
Old Feb 4, 2003 | 09:57 PM
Teal94Z's Avatar
Yep, go with the 1.6 to get the most lift out of those cams...
Old Feb 4, 2003 | 10:00 PM
BPS's Avatar
BPS
cc 305 is a bit bigger - hot cam kit us usually a cheaper option - both are small cams and between the two the differences is pretty small.
Old Feb 4, 2003 | 10:08 PM
Cory_SS's Avatar
True, and for the money I would get the hotcam if I had to pick between the two. Just not enough performance difference in the two for the price. If you decide on the 305, rethink it and go with the 306.
Old Feb 4, 2003 | 10:43 PM
Chad96SS's Avatar
Question XE cams?
What about the XE cams Comp makes? Some of their profiles seem to fall in between a 305 and a 306, but I hear they are hard on valvetrain parts since the valves open and close faster. I want to go a little more radical than a 305 but I live in AZ so there's no way I could get a 306 to pass the sniffer, dammit!
Old Feb 4, 2003 | 10:58 PM
NiteRider's Avatar
Re: XE cams?
Yes the XE's and any step ramped cam will slap your valvetrain parts around.
Small price to pay for a considerable power difference.
Old Feb 4, 2003 | 11:17 PM
MauriSSio's Avatar
the power differences would be unnoticeable,the Hot Cam is a tiny bit smaller but it has less advance ground into it and it has a 112 LSA which would help it rev faster than the cc305.The faster you rev the easier it is to make power so.....power should be about the same considering it has a bit less duration.
Old Feb 5, 2003 | 12:01 AM
Jason Dove's Avatar
CC306 will pass emissions, just takes a bit of work. Just adding that since you said you wouldn't be able to get it passed a sniffer.
Old Feb 5, 2003 | 12:45 AM
NiteRider's Avatar
Uhh... "have you passed" a 306 thru emmissions??? I really am scepticle bout that man. E-mail your emmissions sheet if you can.
Old Feb 5, 2003 | 01:22 AM
1loudz's Avatar
My hotcam was actually a 218 229, 525 525, 112.
I think they may have changed them recently.
-Ryan
Old Feb 5, 2003 | 01:54 AM
snksknr94's Avatar
-Ryan
You get to the track yet?
