Come On Guys, Can't Put My Car Together Until I Know This
Old Feb 4, 2003 | 02:40 PM
JDMZ28's Avatar
I'm doing a 700R4 swap so I'm hooking a detent cable up. I noticed that where the linkage hooks up on my 95 throttlebody is different than on a 93 TBl. So my question is will my throttlebody work? I've been told it would and that all I need is the throttle bracket from a 93 F-body.
Old Feb 4, 2003 | 03:06 PM
rickyzZ28's Avatar
Yes you will need a 93 Throttle body I dont think you can just get the bracket. I know you need the TB for sure but I am not positive you can just get the bracket. This is because the 93 Z28 was the only 4th gen year to use the 4L60 or non electronic 700-R4.
Old Feb 4, 2003 | 03:15 PM
Gripenfelter's Avatar
There is a bracket to hold the cable but the shaft on the 93 throttlebodies is also different. It has a button for the shift cable to attach to.
I bought a 52mm TB and was sent a 95 instead of a 93.
I took apart the 95 52mm TB and inserted my 93 shaft into it.
Works fine.
Thats what you would have to do.
Find a 93 shaft.
If you need help disassembling your TB email me.
DesiZ28@hotmail.com
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Klypto
Jul 24, 2002 11:21 AM
