Good clutch disc for SLP PP?
Old Feb 4, 2003 | 11:49 AM
WOT's Avatar
WOT
I'm told it's the same as the LT4 PP just modified. I was going to go with the McLeod but i did a search and someone said it wouldn't work. What clutch disk should I go with?
Old Feb 4, 2003 | 01:03 PM
atljar's Avatar
stock lt1 disk
GREGG 97Z's Avatar
Do you already have the slp clutch/pp setup? I saw that listed on your mods list, just wondering if you are having a problem with it.
I had checked into the Mcleod disc as a replacement for mine if it ever goes, I heard it would work fine with this PP. This is the disc I would go with from Thunder's site:
37-261871 McLeod Performance Clutch Disk, Shifts to 7500 RPM, 1993-1997 LT1 F-Body
http://www.thunderracing.com/index.c...yid=1100#T1342
Old Feb 4, 2003 | 01:12 PM
Don 97 SS's Avatar
I've had a McLeod disk on my SLP FW and PP for about a year. It grabbed some for the first few hundred miles but smoothed out since then. I'm not certain I'd recommend the combo for oem 3.42 gears (although it will work) but with 3.73 or 4.10s it should be just fine.
Remember with a light weight assembly one will need to feather the clutch a little more off idle to avoid stalling. This is inherit with a lighted FW/PP. Stepper gearing helps. I've got 3.73s. It took about a week to get used to just the SLP combo. With the much better/grabbier McLeod disk this is alittle more pronounced. I am very pleased with the quality of the McLeod disk and would definitely recommend one with an oem FW anyday (unless you have over 400rwhp).
Old Feb 4, 2003 | 03:19 PM
WOT's Avatar
WOT
Yes I already have the SLP clutch and PP with oem flywheel from the previous owner. I'm doing a tranny rebuild (synchros bit the dust) and want to freshen things up with a new clutch and throwout bearing while the transmission is out. The McLeod performance one (7500rpm) was the one I was looking at-thanks.
Old Feb 4, 2003 | 04:19 PM
Teal94Z's Avatar
I may use that one as well, it should hold my heads/cam combo for an occasional drag strip visit, and some daily driving..
Old Feb 4, 2003 | 04:23 PM
madwolf's Avatar
You can just go with the disk slp sells. It's cheap and it works.
Also, I'm pretty sure Mcleod disks will work with this PP.
Old Feb 5, 2003 | 07:18 AM
Don 97 SS's Avatar
The SLP disk is decent street mannered disk, but won't reliably hold over 325rwhp according to the SLP tech rep I spoke with.
I'm sure the McLeod disk will work with the SLP PP and FW, I've had mine in for about a year.
Old Feb 5, 2003 | 08:44 AM
my96z's Avatar
I am running a SPEC stg 3 carbon with my SLP PP. I love it, but its a little on the aggressive side.
Jeff
Old Feb 5, 2003 | 08:45 AM
madwolf's Avatar
I've read otherwise from various board members who have been running this disk with 380-400 rwhp without problems...
Old Feb 5, 2003 | 09:58 AM
Don 97 SS's Avatar
This is confusing.
The SLP disk worked o.k. for me, but I don't drive my car hard or go to the track. I had to replace the SLP disk when my tranny input shaft seal leaked and ruined the SLP disk. That is when I contacted SLP for advice (and ended up going with the clearly stouter McLeod disk. If you saw the SLP and McLeod disks next to one another there would no question which one is the more serious performance disk.
But there is no mistaking the advice I directly heard from an SLP rep. I'm sure SLP is being conservative and playing it safe on rating their products, and I'd do the same. I am just passing along what I was advised.
Old Feb 5, 2003 | 10:13 AM
MYT30TH's Avatar
I had the LT4 PP / LT1 disc , and after six passes w / 2.0 60's that combo. did'nt hold with mods. in my sig. w/ 3:42's ....
Now I have a StreetTwin ...... I figured that will have to be the last clutch I'd have to install
Old Feb 5, 2003 | 10:30 AM
Javier97Z28's Avatar
Moderator
The SLP disk doesn't hold on a 300rwhp at the track when launching on nitto's even at a lower RPM... just ask Dave 96TA
Old Feb 5, 2003 | 11:43 AM
GREGG 97Z's Avatar
Hmmmm, I made 30 passes with mine last season, all with Nitto DR's, 60' of 1.9-2.0, a bunch of 13.0x runs and two 12.9x's. Launching anywhere from 2500-4000 rpm and mine held up so far, with no signs of slipping. I guess it may depend on how hard you slip the clutch on the launch, I didn't slip it too bad, that's probably why my 60' times weren't anything incredible and the clutch is still holding. I would estimate I was right around 300rwhp with all the boltons I had last year too
Old Feb 5, 2003 | 12:59 PM
Mikey97Z's Avatar
I'm using the SPEC Stage III Carbon. It's good for racing, it grabs really hard. I switched from the Stage II Kevlar disk. It was a GREAT street disk. It engaged smooth as stock, but once it grabbed it could hold a lot of force. I took it out after 100 miles though. I needed tranny work done, and while the tranny was out I put the Stage III Carbon disk in. It chattered like a b!tch for a week, but not any more. I hope I get many miles on it. The Stage II disk is for sale if you want it, it barely got dirty. There are pics of all these disks and pressure plates at the link in my sig! Good luck!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
HectorM52
Jan 30, 2015 11:08 PM
mattszm6
Dec 14, 2014 07:09 AM
