How do you rout the spark plug wires?
Old Feb 3, 2003 | 05:33 PM
Punisha69's Avatar
i got the ones going to the right of the motor (drivers side) fine.. but the ones going to the passanger side is not too good.... a couple of them kinda sit on the tensioner pully and i can't really get it so its tight so it woun't tauch... i'm gonna spend some time on it right now.. but anyone have any ideas so i can make it look nice and keep it tight and clean and safe?
yea.. two of my wires got chewed up..
that would explain my hesitation problems..
any advice would be nice
thanks guys and gals
Old Feb 3, 2003 | 06:19 PM
Josh'95Z28conv's Avatar
I used a plastic wire, zip, tie, or whatever you want to call them. I tied them around the power steering bracket(i think). Its still tight with lg motorsports wires, but they do clear the pullies. The headers were another story...
Old Feb 3, 2003 | 08:36 PM
Bud M's Avatar
I used my Dremel with a steel cutting tool to remove a little metal from the ps/alt bracket sp the wires could get around the corner and still all be flat against the bracket (I hope that makes sense) then right after they turn the corner I have a wire loom holding them all in line.
Old Feb 4, 2003 | 08:12 AM
EviLBoX's Avatar
On the passenger side after I routed the wires over the valve covers, I ran the wires back into the stock looms behind the power steering pump and the pulley. I have a few pictures on my webpage if you want to take a look.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
