Advice on many future upgrades
Old Feb 3, 2003 | 05:16 PM
CCRJon's Avatar
I have a concern about what parts to purchase next for my 1997 Pontiac Firebird Formula. I have a huge list of stuff.
Here is the list of items I am planning to buy. I have listed them in the order that I am going to purchase them (eventually, anyway).
Should I purchase one item before another?
Can you folks recommend any items I may have overlooked?
Thanks for the input
CCRJon
DOUBLE SECRET PROBATION CAR PARTS LIST
_____________________________________________
MSD DIGITAL 6 IGNITION SYSTEM
MSD BLASTER HVC COIL USE WITH MSD 6 IGNITIONS
MSD TO GM WIRING HARNESS
POWERSLOT ROTORS X 4
EBC GREENSTUFF BRAKE PADS (all around)
BORLA CAT-BACK EXHAUST
GM RETRO FIT SLAVE MASTER CYLINDER & HOSE ASSEMBLY
CENTERFORCE STEEL FLYWHEEL
CENTERFORCE CLUTCH KIT
COMPLETE 3.43 GEAR PACKAGE FOR GM 7.5" 10 BOLT REAR ENDS
TPIS COATED LONG TUBE HEADERS
TPIS Y-PIPE WITH DUAL CATS
BBK 58MM THROTTLE BODY, 1994-1997 LT1 F-BODY
DRIVE SHAFT LOOP CAMARO/FIREBIRD
MSD HIGH PRESSURE ELECTRIC FUEL PUMP, 43 GPH
AMERICAN RACING TORQUE THRUST II WHEELS X 4
ATI PROCHARGER D-1SC STAGE II W/ TWIN HIGH-FLOW INTERCOOLERS
Old Feb 3, 2003 | 05:35 PM
danner's Avatar
I would focus on CAI, headers, catback then suspension, and then the power adders.
Old Feb 3, 2003 | 08:46 PM
Bud M's Avatar
I'd rearrange that list and add a few things...
Headers first
Then chassis stuff - sfcs etc.
MSD is not necessary until power adder is installed, MSD coils for lt1s have less than stellar reputations from what I've seen on this board
Brakes and clutch when needed
Throttle body and driveshaft loop are probably not necessary at all
Don't forget tires with those new wheels
That Stage 2 blower will put significant stress on your engine, a rebuild with forged internals will be in your future
Old Feb 4, 2003 | 06:26 AM
IDOXLR8's Avatar
Re: Advice on many future upgrades
CCRJon
In my opinion it is a waste of money. I would probably do a MSD ignition coil when your stock one goes bad.
They work great but another option is looking into an LS1 caliper upgrade.
Stay away from Centerforce. Do it right the first time and go with a McLeod Street Twin
I would probably go with a 3.73. I recommend going with a Strange Gear
Another mod that isn't going to do anything for you.
I recommend going with a Walbro 255 lph.
You didn't mention anything about a rebuild. Be warned that regardless of how much boost you run a rebuild is going to happen.
As stated above I would look into the following:
CAI, Catback, Cam, Heads, Hooker Longtubes and depending on your budget a 383 stroker.
ecthemc
Jun 19, 2015 06:54 AM
Firechicken350
Jun 6, 2015 11:25 PM
blkWidow
May 3, 2015 08:42 AM
edxiel
Jan 24, 2015 07:40 PM
