Lifter damage?
Old Feb 3, 2003 | 02:48 PM
ryaskovic's Avatar
Lifter damage?
My engine has lost a bearing in the bottom end and I’ve got metal in the oil. There were metal fragments all through the oil filter element and my magnetic drain plug looks like a Chia Pet. I also noted fine metal filings on top of the spider when I pulled the intake (so I know metal made its way through the engine). The lifters (CompCams ‘R’ series rollers) aren’t that old and look pretty good on the outside…..it’s the inside I’m not sure about. Is there any way for me to insure they are metal-free internally so I can reuse them?
Thanks,
Rob
95Z28
Old Feb 3, 2003 | 02:51 PM
NiteRider's Avatar
Might want to replace them, they could have become a housing for those metal shavings.
Old Feb 3, 2003 | 02:53 PM
You can usually disassemble the lifters, clean them and put them back together. A wire retainer holds in the inner part of the lifter. Compress inner portion and remove the retainer, then the guts will come out.
Old Feb 3, 2003 | 03:00 PM
ryaskovic's Avatar
These Comp Rs have a metal plate instead of the snap-ring style retainer. I'm not really sure on how to remove them without destroying them! Guess I could take a closer look though.
Old Feb 3, 2003 | 03:24 PM
BigDaddy's Avatar
try flushing them out with something.
Old Feb 3, 2003 | 10:09 PM
ryaskovic's Avatar
I don't know if I *can* flush them out without taking them apart. Any ideas?
Old Feb 3, 2003 | 10:16 PM
Wild1's Avatar
Call Comp. They can't be that **** about their product. There must be a way to put them together, so there must be a way to pull them apart. Might require a special tool.
68camaroboltz
Oct 5, 2015 01:46 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
