?'s on rear main seal.
Old Feb 3, 2003 | 01:14 PM
auslandt's Avatar
Question ?'s on rear main seal.
2 questions on the rear main seal for a 97 LT1.
1) I found a one piece rubber and a one piece teflon. Any advice for or against either one?
2) The Hayne's manual states that if a special tool is not available, the oil pan will need to be removed to replace the rear seal. Is this true, or can I just use a piece of PVC to help install it (looks like 5" or so).
Old Feb 3, 2003 | 01:17 PM
97Z-M6's Avatar
the oil pan does not have to be taken off. but you do have to be carefull around it.
Old Feb 3, 2003 | 01:34 PM
97FormulaWS-6's Avatar
I'd say use the teflon. A 4" PVC pipe works great for install, and a large flat-head screwdriver works for removal. Easy swap once you get to it.
Old Feb 3, 2003 | 01:55 PM
Josh'95Z28conv's Avatar
I made the mistake of taking off the plate that the seal presses into. Everything was cool, but there is a lip that goes into the pan, and I had to remove the whole pan just to put the seal plate back on.
Old Feb 3, 2003 | 02:09 PM
JohnD's Avatar
Me too only I didn't do a very good job and the leaking pan ruined clutch disk#2. I sure learned that one the hard way.
Old Mar 12, 2003 | 06:05 PM
Dave88LX's Avatar
What is this plate you speak of?
Was it a screw-up on your part? Or just a "**** happens" type thing...
I really can't afford to have my car down for any longer.
Old Mar 12, 2003 | 06:16 PM
95 Z/28 LT1's Avatar
Super Moderator
The "plate" is the aluminum piece that bolts to the block and holds the seal in place. You dont normally take it off to replace the seal, 'cause the seal just prys out with a flat-head screwdriver. There is three little places or so to pry it out at, you'll see.
Old Mar 13, 2003 | 11:23 AM
TW95Z's Avatar
Here's a couple of pictures I took when I did mine.
http://www.pharmacy.arizona.edu/staf...RMainSeal.html
Old Mar 13, 2003 | 01:23 PM
RocCityZman's Avatar
Screw the special tool. Take the new seal to Home depot with you and pick out the piece of pipe that fits thebest. When I did it I found one with a little lip on it and the seal went in like a champ. Use a piece of 2x4 across the PVC pipe when you tap it in.
Piece o' cake
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
