scoggindickeytpi base
Old Feb 3, 2003 | 11:40 AM
crazyk1le's Avatar
Question scoggindickeytpi base
is anyone running the scoggin dickey intake is it as good as the big mouth or edelbrock intakes?
what i'm trying to do is use the gm fastburn heads with this intake and large tube runners and bigger throttle body on a zz4 short block with an lt4 hotcam later i want to put a supercharger on this combo will it work am i wasting money somewhere it's relly only street driven with maybe some drag time and showtime
Old Feb 3, 2003 | 09:09 PM
Damon's Avatar
I have not used it. However, it's main advantage is that it lets you use some kick-a$$ heads (Vortec or FB). The Vortec and FB heads are really good (as compared to stock) but there are also some really good NON-Vortec style heads out there.
If I was building a full-tilt TPI I'd start with my head choice and work from there, no the other way around.
Even if the Vortec TPI base manifold is a little small compared to some others (don't know if it is or isn't) I'm sure that's nothing that a quick extrude hone wouldn't take care of.
Old Feb 3, 2003 | 11:16 PM
BOTTLEDZ28's Avatar
crazyk1le, I am looking into the same setup. Ilove the fasburn heads but there is only 2 intakes that fit them. The miniram 3 and SDPC one. I just wish I had more info on how good the base is and if it has potential.
Old Feb 8, 2003 | 11:08 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
My dad has one on his car. Its made by Edelbrock, so its the same as theirs but with the right intake bolt pattern and runner shape for the Vortec heads. Yes its a good piece.
http://para.noid.org/~thresher/image...1&dispsize=800
Old Feb 9, 2003 | 10:14 PM
poncho@home's Avatar
Those pics are great!
Actually there is a third choice for FI vortec setups. GM offer a Ramjet intake for the vortec heads. I also beleive that you can use a lot of original tpi parts to make it work, i.e. fuel rails, injectors, wiring harness, ecm. Just need a TB and some other odds and ends.
Myself I am going the Scoggin dickey route this spring. Those pics demonstrate what a quality looking peice that is.
Old Feb 10, 2003 | 11:33 AM
BOTTLEDZ28's Avatar
ya those are nice pics. wonder how well the superram runners bolt to it.
Old Feb 10, 2003 | 01:06 PM
BitchinCamaro's Avatar
The Ramjet is a great choice, and I am going to switch to it once I get my new engine built. (Currtently I have the SDPC base and SLP runners) The TPI fuel rails won't work. You need the Ramjet intake, fuel rails, TB, TPS, and IAC. The tough part is getting the throttle cable and such to work, since they connect on the opposite side of the TB. There is a great, pretty long tread over on Thirdgen.org about the conversion. Plus the set up will only cost what a SDPC base and SLPs will run you.
For a more mild set up (<350 HP) the SDPC base is awesome.
Old Feb 10, 2003 | 01:52 PM
Chuck!'s Avatar
McMillan said you can use an LT4 intake on the Vortecs, and there is a Vortec Mininram.
They're finally getting popular
Old Feb 10, 2003 | 02:24 PM
Nope, LT4 intake won't work on vortecs. It will work (modified) on Fastburns since they have the traditional style bolt holes. I think the same goes for the Miniram.
Old Feb 10, 2003 | 07:32 PM
BOTTLEDZ28's Avatar
so whats the big difference between the HSR and the ram jet? my 2 setups im looking at now are
vortec heads,SDPC tpi intake, SLP runners, ported plenum and mods in sig.
second would be the HSR with maybe a 52MM so it looks nice. which one would be better off
Old Feb 11, 2003 | 11:48 AM
Chuck!'s Avatar
I have no first hand expirence of the vortec/LT4 intake but here is where I got my info.
Why cant you modifiy the bolt holes in the LT4 intake to apply to the Vortec heads like you have to to get them with the normal heads? I thought LT4 bolt holes went directly down like Vortecs, too. Im just curious because if/when I got to an 8 injector setup Id like to use this.
G-BODYT56
Jan 14, 2022 11:14 PM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
drt
Sep 27, 2015 04:39 PM
