Autocross and Road Racing Technique There is more to life than a straight line
Spindle = Steering Knucke?
Old Feb 3, 2003 | 09:33 AM
RobK's Avatar
Question Spindle = Steering Knucke?
Is a spindle the same thing as the steering knucke?
Old Feb 4, 2003 | 11:37 AM
lateapex's Avatar
Technically, no. But the terms are used interchangably on this board.
Bob
Old Feb 6, 2003 | 10:48 AM
eyeoutthere's Avatar
The spindle is the front bearing (the thing the wheel bolts to and turns about). The steering knuckle is what the Spindle mounts too. Then the steering knuckle mounts to your upper and lower control arms and the tie rod.
Old Feb 8, 2003 | 05:42 PM
JasonL's Avatar
Actually the bearing is not the spindle either. That's called a hub-and-bearing assembly.
By the book, a spindle is part of the drive axle. On the rear of my Corvette, the spindle, knuckle, and hub-and-bearing are three very distinct parts. The spindle is what connects to the halfshaft via u-joints, and has splines that turn the outer half of the bearing.
That's splitting hairs though...as mentioned, on the front of a RWD car, the knuckle is often referred to as a spindle.
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
