1.7 ratio rockers??
Old Feb 3, 2003 | 12:00 AM
kgkern01's Avatar
1.7 ratio rockers??
I've seen a few people have used variable ratio rockers and set them at 1.7 ratio. Am I right to assume that this would offer more power than a 1.6 ratio rocker? Does Crane make these, and what kind of valve cover do you have to use with these?
Old Feb 3, 2003 | 03:42 AM
SStrokerAce's Avatar
They will only make more power if your cam is set up for them and your heads flow more at a higher lift.
Comp has some of these that need pushrod guide plates (they are not bolt on self algining rockers) they run about $400 a set but that's better than the Shaft Mounts.
I would think you need longer valves and tall valve covers, but you might be able to get away with them.
Bret
Old Feb 3, 2003 | 04:04 AM
NiteRider's Avatar
You really need to have some high flowing heads to use 1.7 rockers. In most cases you'll do more harm then good by making that much lift.
Old Feb 3, 2003 | 04:29 AM
Joe Brodman's Avatar
GP Moderator
SAR2K is running 1.7 ratio rockers in his N/A bolt-on LT1 (3500lb race weight). Internally stock except for the Crane variable ratio rockers, Isky valve springs (I wouldn't try running 1.7's on stock springs), and ARP rocker studds....I'm assuming guideplates too, though he doesn't list those on his mod sheet. Yeah, the car ran 11.94 @ 111.50 N/A. Stock heads and cam there, and not an overly light car either, nor anything really crazy done to the car.
Dunno, I'd consider it. Check out his thread in the Drag Racing Forum: http://web.camaross.com/forums/showt...threadid=70475
Hey, it worked for him!
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
