Emissions legal cams
Old Feb 2, 2003 | 09:35 PM
Chuckels's Avatar
Would a cam with a 112 lsa be emissions legal. I was thinking about getting the cc305 ground with a 112 lsa. What other cams make good power that are emissions legal still. Also I dont want to rev the engine to 6700. I really want good power but have to comply to emissions. Also if anyone thinks of a cam that would barely pass what needs to be done to pass. Any help would greatly be apperciated
Thanks,
Charlie
Old Feb 3, 2003 | 12:03 PM
Chuckels's Avatar
Anyone? Any information?
TTT
Old Feb 3, 2003 | 12:24 PM
neil350's Avatar
Whats your definition of emsions legal, technicaly no after market cam can be used in any polution controlled vehicle, no matter the size. What your really after is, will it pass smog not comply with emsions.
Old Feb 3, 2003 | 01:08 PM
Chuckels's Avatar
Sorry i want a cam that will pass the emmisions test in my state. I also really dont want the LT4 hot cam i want something bigger.
Old Feb 3, 2003 | 01:28 PM
chevy94c's Avatar
Try the CC503 cam. 224/230 .503/.510 on 114
Old Feb 3, 2003 | 01:57 PM
NiteRider's Avatar
Althought each state/country will vary on it's strictness on emmissions tunning your car for that very reason could probably get you thru emmissions with no problem.
Nothing a good hour or two on LT1 edit won't cure.
Old Feb 3, 2003 | 02:01 PM
WS6T3RROR's Avatar
as the lsa number gets lower the vavle overlap gets larger and the idle will get rougher depending on the size of the lobes. the other side affect which will mean more to your emmissions testing is that as the lsa gets lower the hydrocarbon count goes up. thats why the lt1 cam is on a 116/117 lsa. if you're staying stock heads... you dont need a bigger cam than the hotcam.... i've said it before and i guess i will again the small crane and zz3 or zz4 will eat the hot cam alive on a stock headed car with 1.6 rr's. the trend lately is for the guys with stock heads and a small cam to eat the guys with a bigger cam alive on the drag strip. the highway might be a different story, and peak numbers do give braging rights but its avg power that counts not peak. thats why you see some of the dyno queens on here run **** numbers at the track. also the 224/230 is probably going to be the top performer on stock heads if you MUST go with a bigger cam. however i dont know about it passing emissions
its not about BIG with cams its about OPTIMIZING what you have
Old Feb 3, 2003 | 02:09 PM
NiteRider's Avatar
Coulden't agree more, pay attension to those lift numbers stock heads don't flow very much and like we already touched earlier on to much lift will hurt you on a stock head setup.
Old Feb 3, 2003 | 02:21 PM
WS6T3RROR's Avatar
also notice the cams i recommended the crane is a 210/224 the zz3 which is in theory better than the crane is 208/221 notice a trend here? the stock lt1 exhaust port SUCKS!!!
NewsBot
Apr 10, 2015 03:10 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
Queens94z28
Nov 20, 2014 06:03 PM
