A/C causing vibration & loud noise when on
Old Feb 2, 2003 | 05:46 PM
Bawls's Avatar
Driving to work today, started hearing what sounded like my horn, thought maybe some wiring got messed up. My AC hasnt been working since I bought the car, so I turned the **** to the floor setting (guessing it was because I had it on the Upper/Lower setting), and the "horn sound" went away. Now everytime I turn the car on, it sounds off for a second, and when I turn on the Upper/Lower fan I get the same noise and vibration.
Anyone got any ideas?
Edit: Heater blows fine. It sounds like something is grinding when I turn on the AC, or defrost (well duh, ac is part of defrost. ) All other settings in cool through warm on the temp dial work fine if its in either upper or lower.
Edit2: it's not the horn. Im just saying, it sounds like a horn
Edit3: If the AC pump is under the alternator then I found out where the sound is coming from. Car has just turned 139k
Old Feb 2, 2003 | 06:19 PM
drop top steve's Avatar
Sounds like the ac compressor died, you can unplug the two wire connecter to disable the ac.
Old Feb 2, 2003 | 06:23 PM
Yeah, the compressor is under the alt. Guess you got a problem with it. You can pull the compressor fuse so you can use those mode positions without engaging the compressor, if you want.
Old Feb 3, 2003 | 11:41 AM
Bawls's Avatar
Thanks, I removed the relay. So whats next? How much is it to replace one? Should a mechanic do it, or is it possible to do it with hand tools?
Thanks.
Old Feb 3, 2003 | 11:54 AM
Thanks.
As far as physically removing and replacing the compressor, you should be able to do that. Watch out for the refrigerant under pressure. Bleed it off with the shrader valves.
My opinion is that the evacuation and recharging of the system should be done by a professional so that you can be sure it is done right. You don't want to waste a new compressor because of ignorance.
Old Feb 3, 2003 | 12:53 PM
Bawls's Avatar
werd
HarleyZ28
Oct 5, 2015 06:23 AM
BigWil
Mar 29, 2015 12:24 PM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
squarehead
Nov 21, 2014 08:02 PM
