OBD1 diagnostic port pinout
Old Feb 2, 2003 | 05:37 PM
Hotwire's Avatar
Hey all,
Just trying to tie up loose ends on this LT1 swap and need some help.
I'm trying to splice the LT1 harness into the S-10 and need to know what wires go where on the diagnostic port.
If anyone could just run off the the numbers, 1-6, 7-12, I'd greatly appreciate it! The pcm has already been programmed by Ion Soltan and I have the program and cables to get into it a little myself, just need to get everything together.
Pretty soon I'll be makin pony boys weep!!!!!
thanks guys,
Jeff
Old Feb 2, 2003 | 05:47 PM
turbo_Z's Avatar
01 02 03 04 05 06 07 08
09 10 11 12 13 14 15 16
05 = Ground
06 = Mode Select
09 = Serial Data
heres the other one but i thought in your sig is say you have a 95 in which case youd use the top one but heres the 12 pin
F E D C B A
G H J K L M
A = Ground
B = Mode Select
M = Serial Data
Old Feb 2, 2003 | 05:50 PM
DLC pinouts
Old Feb 2, 2003 | 05:59 PM
Hotwire's Avatar
Talking
Rob,
dude, you are the man. you can add me to the list of "owe beers."
I can't wait to get this truck on the road, you are helping me a bunch!!!
Thanks,
jeff
Old Feb 2, 2003 | 06:02 PM
Originally posted by Hotwire
Rob,
Thanks,
jeff
Give turbo_Z some credit. He typed all that stuff out.
(maybe he cut and pasted, but the effort was there )
Old Feb 2, 2003 | 06:07 PM
turbo_Z's Avatar
i will admit your reply was far better than mine. and btw...i did cut and paste
Old Feb 2, 2003 | 06:13 PM
Hotwire's Avatar
lol, preciate it guys, I really do appreciate all the help.
also, thanks turboz, I saw your reply as well and was getting ready to print it out when rob popped up. your diagram is heads on too, but there were more than three hooked up to the original port on the s-10, and was curious if i needed anything else connected.
I really do appreciate all your time guys, you make the forum worthwhile.
Jeff
Old Feb 2, 2003 | 06:22 PM
madwolf's Avatar
Jeff
Just noticed your email Jeff... looks like I'm a little late.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
Aug 7, 2015 01:26 PM
